Results 1 to 10 of 10
Thread: Copper drain pipe for tub
    DIY Junior Member dnile's Avatar
    Aug 2010
    Saskatchewan, Canada
    Default Copper drain pipe for tub
    Hello Forum,
    I need some advice regarding some drainage. I am currently remodeling the upstairs bathroom and we are changing out a tub. Just had a question regarding the drain, I am unable to pull the tub out because the compression fittings. I was thinking about just cutting the pipe that goes to the bottom of the tub so I can pull out the tub. Please let me know if there might be an easier way looking at this picture...
    Also, I am guessing that the new tub will have abs drainage pipes so I will have to adapt to abs. What is a good way to cut the copper with a hacksaw so I can get a nice straight square cut.
    Thanks, Cheers.
    Dec 2007
    I usually unscrew the flange in the tub and remove the overflow plate...
    Aug 2010
    Ok I have disconnected the overflow, but the cross hair piece on the flange is gone... There doesn't appear to be anything to grab onto with... I will try sticking a set of channel locks in there and try turning it out.
    Assuming you aren't trying to save the tub (or even if you are), the way to get the strainer off is to take a hacksaw and cut out a small piece. Then, stick a screwdriver in there as a pick to then turn it using that wedge you cut out as a socket.
    Aug 2010
    Unfortunatly I wasn't able to remove the flange. But a quick cut with the sawzall and we got the tub out. Now onto the second part of my question...
    How do you create a nice square cut on the piece below the tee so I can connect it to abs via an adapter?
    You do NOT want to connect to that piece because it already has corrosion on the outside, besides being soldered into the tee.. Take it out of the compression joint at the bottom and connect the new drain to it. The tub does NOT come with a new drain so you can purchase either a metal or plastic one.
    Aug 2010
    I ended up cutting about 3 inchs below the tee. Going to use a banded copper to abs adapter... will this suffice?
    A no-hub connector will work, but you probably will have to go to a real plumbing supply store to find one the proper size. The big box stores generally only carry one for CI or plastic drain pipe...you need one side to be smaller to seal to the copper. An all rubber one without the metal reinforcement is not proper for above ground use. Keep in mind that the drain for the tub is tubular, and thinner and smaller diameter than the normal drain pipes, so you'll have three different diameter things to deal with.
    IF you use an ABS sch. 40 drain assembly, then an ABS to copper TRANSITION coupling will work. If you use a tubular waste, (ABS, PVC, or copper), then a "trap adapter" is the fitting to use.
    Aug 2010
    This is what I got for an adapter. On it, it says: 1 1/2" CI PL ST to 1 1/2"K, 1 1/4" PL,ST. On their website they say K is copper. So I believe, this should work?
  1. Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
    By speede541 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2011, 10:44 PM
  2. Shower Drain help - copper drain pipe
    By zoomzoom3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-12-2008, 11:23 AM
  3. Copper Drain Pipe for shower
    By hungryeye in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-11-2008, 06:36 PM
  4. Twist N Set Closet flange on 3" short sweep copper drain pipe
    By OneProject in forum Toilet Forum discussions
    Last Post: 11-01-2007, 05:56 AM
  5. Connecting metal drain to copper waste pipe
    By jlongo08889 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-28-2006, 09:26 PM
