Results 1 to 2 of 2
Thread: Musty Odor From Sink Drain
    DIY Junior Member RedClay's Avatar
    Aug 2008
    Somewhere in the vast spaces of time
    Default Musty Odor From Sink Drain
    Hello all,
    We are in a six month old rancher with a walk-out basement. Recently, the sink drain in the main level 3/4 guest bath has been giving off a musty odor when we run water. It is definitely coming up from the drain, and it is not the water itself.
    The sink is used several times a day for hand washing only. The shower is used three or four times a week. All the plumbing under the sink appears perfectly normal. The drains work fine. There are four other sinks in the house, also all on the main level. None of them are giving off the musty smell.
    There are two floor drains in the basement. The closest by far receives the condensate from the AC, so I know its trap is full. The other one is at the other end of the house. It is probably dry, but no odors come up from it. We are on a septic system. The water is municipal The house was plumbed by one of the best known companies in the area.
    Thoughts?
    Dec 2007
    Clean the sink drain and the overflow on the smelly sink.
    Someone is probably brushing their hair over the sink and there is a stanky hairball under the pop up stopper.
    Do you know how to remove the pop up stopper?
  1. Under sink odor
    By tf123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2010, 10:41 AM
  2. temporary odor when sink is turned on.
    By fisrtomni in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2007, 07:07 PM
  3. Duel Kitchen sink odor
    By ChuckO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2006, 12:52 PM
  4. Musty odor in all drains
    By angie in forum Shower & bathtub Forum & Blog
    Last Post: 10-12-2005, 06:01 PM
  5. foul odor from new bathroom sink
    By BeverlyW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-04-2005, 04:36 PM
