Results 1 to 6 of 6
Thread: 2nd expansion tank in 4 months
    DIY Junior Member pllckjsh's Avatar
    Aug 2010
    ohio
    Question 2nd expansion tank in 4 months
    Hey guys looking for a little info here..I am the head of Maintenance for a big hotel chain in ohio..this is the problem we have 3 hot water heaters in one room all have expansion tanks...in april we noticed one of the expansion had a pin hole in it and was shooting water across the room...so we replaced it and just noticed today that the new expansion tank is leaking now. what would cause these to go bad so fast.The two other water heaters still have the original expansion tanks on them and both still look new. These water heaters are about 7 years old.....thanks in advance guys
    Josh in ohio
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    Did you use the proper potable water expansion tanks? Whats the model number of the new one that failed?
    If you used a boiler expansion tank designed for a closed system, the oxygen in a open system would eat through it quickly.
    Potable expansion tanks for DHW systems have a liner inside the tank similar to a milk jug.
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    Aug 2010
    ohio
    I just talked to the maintenance guy who replaced it he said the new tank is a Extrol 30 4.4 gal hot wat0001.....he said he got it from johnstone supply
    Dec 2007
    Extrol is used for Hydronic heating so it is the wrong one.
    Amtrol Therm X Trol is for domestic hot water applications...
    http://www.amtrol.com/thermxtrol.htm
    Aug 2009
    Texas
    Yep as I expected, you have the wrong type
    Expect to pay 2.5X more for the correct tank
    Johstone # L86-193, L86-194, L87-200, and L87-201 are the potable water tanks.
  1. Expansion Tank
    By foxhome01 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-09-2009, 06:58 AM
  2. Do I need an expansion tank, new PRV or both???
    By aballard5 in forum Water Heater Forum, Tanks
    Last Post: 03-15-2009, 06:49 PM
  3. Expansion Tank
    By cthudak in forum Plumbing Forum Discussion & Blog
    Last Post: 10-24-2008, 06:13 AM
  4. Hot water tank expansion tank vs T&P valve.
    By Mikebarone in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2008, 09:39 AM
  5. Expansion Tank - Which One?
    By jk60 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-20-2005, 09:35 PM
