Thread: Sink drain rough-in... to 1960's era male threaded bronze?
    king overbudget dfv2's Avatar
    Aug 2010
    Upstate NY
    Default Sink drain rough-in... to 1960's era male threaded bronze?
    Nice forum! Been lurking a while, finally needed to register and ask some questions. My name is Steve and I've been renovating my 1960's ranch bath for the last month (yes, month).
    FINALLY, I'm trying to decide what to use for my sink drain. Stubbed out from the wall is the original male threaded 1-1/4 fitting, soldered to 1-1/2 copper which runs to a 4" copper drain/vent stack.
    Should I go PVC or brass (chrome plated stuff)? Would you guys typically connect to the threaded fitting with an extension, and a nylon washer/screw ring? I'm a little lost on this type of plumbing and need some suggestions. If needed I'll take a pic. FYI this will all be hidden within a vanity so no issues with it looking overly pretty.
    Steve
    ME
    Dec 2007
    I would just use the 1 1/4" plastic tubular as long as the pipes are in the correct location for your vanity...
    If they are not in the correct location they should be moved before hand...
    Aug 2010
    Upstate NY
    thanks! I was watching holmes on homes, and his plumber guy was using a fernco to transition from the copper stub-out to abs. I just want a worry-free connection as I won't see a leak until it damages a LOT of stuff back there.
    Steve
    ME
  1. Square Oil Rubbed Bronze Shower Drain
    By rdtompki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2011, 09:13 AM
  2. Shower Valve Inst - Male Threaded fittings or Unions?
    By Remodelboy in forum Shower & bathtub Forum & Blog
    Last Post: 01-24-2008, 06:59 PM
  3. Bronze/brass vs. plastic shower drain
    By bmw3034 in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2007, 07:48 PM
  4. Threaded male adapters onto new shower diverter..?
    By lithnights in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2006, 07:09 AM
  5. Rough-in hight of sink drain?
    By tjbaudio in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2006, 01:33 PM
