Thread: question about plumbing
    DIY Junior Member bronzemaxell's Avatar
    Jun 2010
    earth
    Default question about plumbing
    Hi
    i am in the process of hooking up my water filters
    i have a check valve between the well submersible pump and right before the pressure switch relay then to pressure tank.
    then pressure tank to sediment filter to pH filter to water softner to house
    i am aware of the in and out on the control valve
    can or if the water flow in reverse direction, will the resin in the tank back flow and travel to the house pipe?
    is it a bad idea to put an other check valve between pressure tank and sediment filter to prevent water to flow in reverse direction?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Please be sure you have a thermal expansion tank installed on cold inlet to your water heater to protect the tank and your warranty !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    In the Trades Wally Hays's Avatar
    Nov 2009
    get rid of any check valves. You don't need them and they add to the restriction of the system.
    Perception is 3/4 of reality
  1. Plumbing question- PEX
    By new_home_owner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2009, 06:06 AM
  2. Plumbing question
    By catk9 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2007, 12:24 PM
  3. Plumbing question
    By HoneySuckle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2006, 05:04 AM
  4. CI Plumbing Question
    By brody-o in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2006, 02:14 PM
  5. Tub plumbing question
    By ppitts in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2005, 01:48 PM
