Results 1 to 7 of 7
Thread: 4 inch vent pipe in a 2x6 stud wall?
Hybrid View
    DIY Junior Member Antonio4791's Avatar
    Jul 2010
    South Pasadena CA
    Default 4 inch vent pipe in a 2x6 stud wall?
    Hi all, I just built a 2x6 stud wall for my new bathroom. I would like to put in a 4 inch vent pipe but I'm wondering if 4 inches is too wide. Obviously there are code issues with boring studs, but what about top and bottom plates? This is a load bearing, double top plate wall. A 2x6 is only 5.5 inches wide and the OD for "4" inch DWV pipe is 4.5 inches, leaving only a half inch on each side of the plates. That seems too big to me. I suppose I can get by with 3 inch. I would like to do to the toilet drain with 4 inch and would like to have the vent be the same size. Is it OK to have toilet drain by 4 inch and the vent be 3 inch?
    Jan 2006
    Rosedale, Md
    Depending on the load of your system, you could vent a toilet with a 2in line, unless you have an extreme load on your whole system 3in should be fine.
    Plates only support things where they cross. We drill 4" pipes through 6" walls all the time, otherwise there would be no way for us to install our piping.
    In the Trades Wally Hays's Avatar
    Nov 2009
    Double up the studs on either side of the pipe and plate it when you are done.
    Perception is 3/4 of reality
    NEVER have had to reinforce the wall after installing a vertical 4" stack. Just as I have never had to do it with a 2" pipe in a 4" wall, which would have the same problem, if it were a problem in the first place.
    Nov 2009
    IPC wants simpson ties top and bottom on exterior or load bearing walls because......... If there is a fire in the house that portion of the wall can be weakened bu the fire and when the fire department puts the water to the exterior it can blow the wall in and crush or trap fire fighters that may be inside. I know it's a long shot but apparently it has happened more than once.
  1. Best way to build stud wall where joists run parallel?
    By ironspider in forum Remodel Forum & Blog
    Last Post: 01-26-2010, 05:54 PM
  2. Is it OK to have a water meter behind a stud wall..
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2009, 06:08 AM
  3. Alcove stud wall coverings not covered by surround?
    By topshot in forum Shower & bathtub Forum & Blog
    Last Post: 08-07-2009, 10:18 AM
  4. Does entire shower stud wall need to be pressure treated?
    By Mike Fresh in forum Shower & bathtub Forum & Blog
    Last Post: 12-07-2008, 07:55 PM
  5. Rotten Stud(s) Replacement and PVC Vent Line
    By Seattle_Scott in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2007, 08:30 AM
