Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Replacing resin
    Computer systems technologist for Geologists & Petroleum Engineers MiddleAgeSoftie's Avatar
    Mar 2010
    Calgary, AB
    Default Replacing resin
    Ok. I've done it. I've disassembled my water softener (cabinet model - see previous post here) cleaned it all out and removed the resin from the tank. It's a lovely orange colour (I don't think it's supposed to be that colour...is it?). Now I'm committed - I need new resin. What do I need to know? The size of my tank is 10"X35" I live in Calgary. Information regarding the nature of the water in our area is here and here - My water comes from the Glenmore water treatment plant. There are six people in my house... If there's anything else you need to know in order to help me find the right resin for my softener just ask
    So, basically I need to know everything about resin and replacing it. How much do I need? What kind? Are there any tricks to replacing it? Any details I need to know about putting the softener back into service once I've got it all put back together.
    Thanks in advance for any advice you may be able to provide.
    In the Trades Wally Hays's Avatar
    Nov 2009
    Did you keep the old resin? ( orange-ish is about right for the color BTW )
    What made you think you needed to replace it?
    How big is the tank ( diameter and height)
    Was there a gravel under bed?
    Is the distributor tube still in working order?
    You need more information than you have provided here.
    Perception is 3/4 of reality
    Mar 2010
    Calgary, AB
    Hi Wally. The softener was out of service when I bought the house. I plugged it in opened the valves and let 'er rip. The unit it's self appears to be about 25 years old. As near as I can determine it's all original. Nothing has ever been changed. You can see some photos of the unit from a previous post which I've linked above. There was a lot of "goop" in the bottom of the cabinet when I disassembled it.
    I do still have the resin although it's in a couple of old pails that weren't that clean to begin with so I would be concerned about putting it back in. The tank size is 10"X35". There was no gravel under the resin. If by distributor tube you mean the one that runs from the control valve down the centre of the tank, then yes it appears to be in working order although the screen/slots in the bottom were clogged with resin beads which I picked out with a tiny jewelers screwdriver.
    Again, thanks for any advice you can provide.
    The color is determined by the manufactor not if it's bad or not. You have a 1 cu ft tank so 1 cu ft of resin is in the tank. Your resin may not be bad at all, but if you really want to replace it, you should replace the distributor as well. Think of the time and cost to replace the resin. If the distributor tube breaks in 2 months because of age, you may lose all the new resin. An under bedding of #20 flint (about 15 lbs) should be used to protect the distributor. Ask for a funnel when you buy the resin. The cost is about $3.00. Tape the top of the distributor tube to prevent resin from getting it and place in tank. Pour gavel in then resin. Rinse, remove tape anmd replace valve.
    Mar 2010
    Calgary, AB
    Hi Skip. Thanks for the tip about he distributor tube. I'll do that. I'm sure I can get this all together if I can just get the right materials. My first problems are; where do I get this stuff and what stuff do I get. I don't really know where to get started. Any advice?
    Dec 2009
    Alaska
    There is a stress test that I was thought for the distributor tube,
    Hold one end in each hand and try to make a bow, one does not have to go far with this, but if the tube is about to go it will change some color or not bend at all with out breaking.
    The size of distributor is based on the size that the valve is going to need, there is the 3/4 and the 1". then there is the bell or bottum distributor basket that will be 3/4 or 1" .. some call it 13/16 or 1.050.... the the about of tube needed depending on the distance from the distributor to the top of the tank.
    If there was no gravel in the tank, then you could go that way again and not put gravel at the bottom of the tank.
    Next?
    By the time you get done, you could have a new softener installed, for a lot less labor, and maybe about the same dollars.
    Nov 2009
    I was thinking the same thing.
    Dec 2009
    Alaska
    And what goes to the land fill?
    Mar 2010
    Calgary, AB
    Now you tell me... ;-) This is more of a voyage of discovery exercise than a "how can I replace my softener as inexpensively as possible."
    I have done the flex test with the distributor tube. I believe that it is sufficiently durable to go back in without being replaced. I have a funnel. I've been doing some reading about how to replace the resin. It seems pretty straight forward if I can only find out were to get it. I've contacted some web retailers to see if they ship to Canada. So far I've gotten one "...Sorry we don't ship to Canada..." and one "...Yes we ship to Canada but it'll cost you between $30 to $60 for shipping plus brokerage...". I'm awaiting a few other responses. I also found something on E-BAY - Item # 400063246570. Is this what I'm looking for?
    Why do you feel the resin needs to be replaced? Get some in you hand and pinch it. If it smaches up, it's bad. If it stays hard, it could have years of life left.
    Mar 2010
    Calgary, AB
    I presumed that after all this time it was probably tired - used up, and needed to be replaced. I thought that because it was a salmon-egg orange colour that that was an indication that it was worn out (Iron). As I've mentioned above I do still have it but the buckets I put it in weren't particularly clean. I don't suppose it's a good thing to get contaminants in with the resin. Can this stuff be washed with normal tab water? I did as Skip suggested. It does seem to stay hard - it doesn't smear into a paste or anything like that. I'd post some photos but I don't presently have a cable to connect my camera to my computer. I'd rather not spend money if I don't have to but at the same time I want to make sure that this thing is going to work when I put it back together.
    Again, any sage advice is appreciated.
    Nov 2009
    Put it back in along with a couple tablespoons of iron out, re-connect everything and run it through back to back re-gens.
    Mar 2010
    Calgary, AB
    Ok. So do I need to worry about the resin that is "contaminated" (got bits of other stuff - tile grout, dirt etc.)? Should I just try to avoid that stuff?
    Nov 2009
    get rid of any large pieces you see the rest should flush out
  1. recycle used resin?
    By wadewood in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-10-2010, 08:47 AM
  2. New resin for model 60
    By ChuckB in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-05-2009, 04:39 AM
  3. Resin in Screens
    By pulpfiction1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-31-2009, 08:01 PM
  4. Can I check Resin to see if its bad??
    By ArayT in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-27-2009, 05:36 PM
  5. Resin Tanks
    By biznitch15 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2008, 05:56 PM
