Thread: Price Pfister brass acrylic 3 handle shower. Can it be replaced with original?
    DIY Junior Member redwater's Avatar
    Jul 2010
    California
    Question Price Pfister brass acrylic 3 handle shower. Can it be replaced with original?
    I am helping my mom re-finish/ fix her faucets.
    In particular, this acrylic-brass handle is beaten up and needs a new acrylic handle.
    Do you think it is available/ know the model number/ name and /or have a recommendation of replacements?
    thanks!
    Plumber jimbo's Avatar
    That is the second most common shower set up ever used, at least west of the Rockies! The only one you find more is the just slightly older Price Pfister Windsor, and the parts are interchangeable. The only problem is, the polished brass was not so common, and I don't know if you will find that at all today. But if you can use chrome or brushed nickel, you will find it a HD, Ace Hardware, and probably the corner drug store!
    You don't have any other options. The trim pieces, and the internal stems, on all showers, are unique and not interchangeable between brands. That is the handles only. You can install vrtually ANY shower head and tub spout that you would choose. Also, the drain trip lever and tub flange are in a sense " generic". There are more thatn one size of trip buckets. Since your drain just has a grid held in place by a long #10-32 screw, you can replace the grid without unscrewing the whole flange.
    A good plumbing suppy store ( probably not HD) can fix you up with all those parts.
    You can use the Windsor handles or the acrylic ones for the newer models which are similar to yours. And, when it comes time to repair the faucet, a good knowledgeable plumber, would be able to convert that faucet to the new "lifetime" ceramic stems, (I would have done it while doing the handle repair). But do not try to do it yourself, or you could wind up having to replace the faucet inside the wall.
  1. Price Pfister 3-handle shower leak
    By Mr. Pickles in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2014, 04:07 PM
  2. Help find a replacement handle/faceplate for Price Pfister Shower Valve.
    By jeffeklund in forum Shower & bathtub Forum & Blog
    Last Post: 07-22-2010, 06:52 AM
  3. single handle price pfister shower faucet
    By don640 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2008, 07:37 AM
  4. Help me identify and upgrade old Price Pfister 3 handle tub/shower
    By prpsrv in forum Shower & bathtub Forum & Blog
    Last Post: 08-13-2008, 07:09 AM
  5. Replaced Price Pfister Valve Stems -- Water coming through ceiling
    By mbloom in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2008, 09:23 AM
