Results 1 to 5 of 5
Thread: Thin stream of water from bathroom faucet
    DIY Junior Member dcgardener's Avatar
    Mar 2010
    Washington, DC
    Unhappy Thin stream of water from bathroom faucet
    Okay, this has been an ongoing (years!) problem. We have extremely low water flow from our downstairs powder room faucet, even though we have excellent water pressure elsewhere throughout the house. The faucet is Jado's single lever New Haven jobbie.
    Our first thought was the aerator was clogged, so we checked, but that was okay; no debris. There's no low flow regulator reducing the amount of water either.
    When a plumber was here recently on another job, I asked him to take a look to see whether the supply lines were the right size (my husband thought perhaps that might be the problem). The plumber said nope, the lines were fine and the problem was likely inside the faucet.
    I have Jado fixtures in the master bathroom and have never had a problem with them, but who knows; I guess this could be a bum one.
    I'm at a loss as to how to fix this problem. It's way frustrating. Any ideas??
    OPen it full, and measure how much comes out in say 30-seconds, then double it. Newer vanity faucets are limited to 2.2gpm (or less). Some faucets have screens on their inlets. Take the supply line off the shutoff, and run that into a bucket to see if that has better volume. if the faucet has removeable supply lines, remove it from the faucet and see what volume there is there. The shutoff valve, if a multiple turn, might need replacing (it's often easier than replacing the washer). If itis the source of the problem, replace with a 1/4-turn one...no washer to fail.
    In the Trades ilya's Avatar
    Dec 2009
    Akron Ohio
    Are both hot AND cold doing this? If a bibb washer fomt the shutoff has degraded, peices of it may be stuck in the faucet body. I once found this in a showerhead, from a shutoff in the basement.
    not a licensed plumber
    If the stream does not change volume regardless of whether it is all cold, all hot, or in between, then the problem is in the faucet somewhere.
    Dec 2009
    Akron Ohio
    I wouldn't got to the trouble and expense to replace the faucet yet. Remove the aerator and supply lines, open both hot and cold sides then shoot compressed air into the spout using short, tiny bursts.w/ a short tube and lungpower. It may be that bits of rust or corrosion lodged in the faucet body from the surge of water being turned on the first time. They usually travel clear thru to the aerator, though.
  1. Looking for "thin" ADA bathroom sink
    By reny90077 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2009, 09:16 AM
  2. no hot water when using the bathroom faucet
    By miss mary in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2007, 06:47 PM
  3. Underground Stream?
    By lisacan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-23-2007, 07:40 AM
  4. Steady stream of water from my Bath Faucet
    By mic in forum Shower & bathtub Forum & Blog
    Last Post: 08-18-2006, 06:43 AM
  5. No water from bathroom faucet
    By spike808 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2006, 07:13 PM
