Originally Posted by
Yankee1423
I was putting up drywall in the basement this weekend and took a quick look behind the insulation on the exterior wall before putting the gypsum up. In the above grade area of the basement wall, I put in 1.5" XPS between stud bays and then spray foamed the edges. I then put in unfaced batts to fill in the remaining stud space. Removing the studs here was not an option. The temps have dropped to the single digits and when I pulled the unfaced batts back, I noticed some condensation on the interior side of the XPS. In one spot it was frosting on the XPS. I used a ton of the Great Stuff to seal all the edges completely and then some. Is this going to be an issue once I put the drywall on?
