Results 1 to 2 of 2
Thread: Need to verify appropriate size of softener
    DIY Junior Member 606zpx's Avatar
    Jul 2010
    Savannah GA
    Default Need to verify appropriate size of softener
    Alright...I sincerely appreciate the assistance:
    2 full bathrooms-regular shower heads
    2 people, 3 dogs
    Wash boat and car at times
    may run d/w and/or washing machine while showering
    3/4 copper coming into house
    City water, 6gpg
    Looking at Aquapure softeners (Clack ws-1 cs head) see PDF
    http://aquapure.com/apspecs/LITAP880CWS.pdf
    From a grain standpoint a 0.75cuft would suffice but probably need 1cuft for flow rate and possible growth in number of people (which would make it more likely that both showers would be running while someone is washing a car, etc).
    ALSO....the aquapure guy suggested a sediment filter but I have not seen this as a standard suggestion....truly necessary with city water.......I have not noticed a significant sedimentary issue.
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    I would go with the 1 cubic foot.
    Set it up with 3 lbs of salt/regeneration and 12000 grains capacity. 14 day override. Program P7. I would not install a prefilter--it is not necessary.
  1. Pump Size, Pipe Size, CSV location????
    By fausdick in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2009, 05:40 AM
  2. Size a faucet to the room size?
    By chrisexv6 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-06-2008, 07:09 AM
  3. how to verify if drain pipe passes code (cast iron below grade)?
    By beethovengirl in forum Plumbing Forum Discussion & Blog
    Last Post: 05-31-2007, 08:55 PM
  4. Need the experts to verify this plan
    By jgbfl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-03-2007, 06:09 AM
  5. Soldering drain pipe from tough angle..standard test to verify solder took?
    By lithnights in forum Plumbing Forum Discussion & Blog
    Last Post: 03-24-2006, 07:29 AM
