Results 1 to 6 of 6
Thread: Adding service extension before pressure tank...
    Default Adding service extension before pressure tank...
    I have a new detached garage. I need to add service to the garage. I also have a huge problem with sediment and several sediment filters. I was hoping to connect my service before the sediment filters (I will also use this service to water the garden). However, the sediment filter sits before the pressure tank. I seem to recall, in the back of my old mind, that one should not add a service in front of the pressure tank. Is it correct that you should NOT add a service between the well and pressure tank?
    Partly it depends on where the check valve is. If you connect prior to the check valve, you will only get water while the pump is running and the pressure will be uncontrolled. The other factor is if you do connect after the check valve, every time you use the water, it will be coming out of the pressure tank, and thus "backflushing" the filter.
    In the Trades mattbee24's Avatar
    Mar 2007
    Fremont, OH
    Really, it's not a good idea to have a filter before the pressure tank. If the filter gets plugged up, you could have a situation where your pump will never shut off.
    The check valve is on top of the pump in the well. Actually, backflushing the filter would be positive thing in most cases. My filter fills up very quick. None of the water from this extension would be used for drinking. It would be used to water my garden and general shop use (e.g., wash my hands mostly).
    Quote Originally Posted by mattbee24 View Post
    Good point. I going to remove this filter. Too risky.
    quote; None of the water from this extension would be used for drinking.
    And how would you ensure that no one would EVER drink water from the hose?
  1. Service Pressure
    By rseand in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2010, 04:44 PM
  2. adding another hot water tank
    By rtyauch301 in forum Water Heater Forum, Tanks
    Last Post: 01-14-2009, 02:24 PM
  3. Adding second pressurized well tank
    By pioneerz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-13-2009, 11:09 AM
  4. Adding a service
    By noweare in forum Shower & bathtub Forum & Blog
    Last Post: 01-19-2008, 04:31 PM
  5. Adding Very Large Pressure Tank?
    By cockybull in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-06-2007, 07:05 AM
