Thread: Closet Flange Mounting Bolts and Wax Ring for Toto CST743E
    DIY Junior Member PhilLB's Avatar
    Jul 2010
    Falls Church, VA
    Default Closet Flange Mounting Bolts and Wax Ring for Toto CST743E
    I just purchased the Toto. Came with installation instructions but no indication on size of the wax ring or the length of the closet flange mounting bolts required. Recommendations? Thanks.
    Phil
    Instructions by Jamie
    Does your flange rest on top of the finished floor as it should or is is recessed? If it is on top of the floor, then a standard wax ring with no plastic funnel is all you need. If the flange is recessed, then a thick wax ring would be in order. If the flange is considerably recessed, then spacer rings could be used. We really need more data on your situation to be more specific. As far as flange bolts are concerned, it is not difficult to shorten long bolts. A lot of us find using an extra nut to secure the bolts to the flange in an upright position to be helpful. Set the toilet on the flange without a wax ring to determine where to cut the bolts. A file to sooth the cut end helps get the nuts started. I'd suggest trimming the bolts to length before installing the toilet. It's a bit tricky sawing them when in position. The length does not have to absolutely perfect, there is room for a tad more length than actually necessary. And, if you screw up, the toilet isn't damaged and new bolts are cheap.
    Hardware store items for toilets
    Notice that the bag of bolts includes four nuts and four washers.
    Clear caulk
    There are some brass toilet bolts that have notches milled into them so you can break them off at the needed length. I find it best if sawing them off, to put a nut on first, then when you back it off, it cleans up the threads. File it smooth first, and it should be fine. Those designed to snap off don't need the file or nut trick.
    Jul 2010
    Falls Church, VA
    Gary and Jim - thanks for the advice. This is very helpful.
    Phil
  1. Toto CST743E noise when flush starts and stops
    By kevintoto in forum Toilet Forum discussions
    Last Post: 11-09-2009, 09:52 AM
  2. Toto Eco Drake (CST743E-round)-comments?
    By Homeowner Bob in forum Toilet Forum discussions
    Last Post: 02-25-2009, 02:22 PM
  3. closet flange ring rusted out in concrete slab????
    By jkrause in forum Toilet Forum discussions
    Last Post: 10-13-2007, 07:43 AM
  4. Setting a Toto Aquia - Flange & Wax ring?
    By ss3964spd in forum Toilet Forum discussions
    Last Post: 10-10-2006, 05:16 PM
  5. Floor mounting ring
    By balld in forum Toilet Forum discussions
    Last Post: 07-03-2006, 03:53 PM
