Results 1 to 2 of 2
Thread: Are shower VALVES restricted? IOTW do the shower and tub side flow the same rate?
    Default Are shower VALVES restricted? IOTW do the shower and tub side flow the same rate?
    I was told and I doubt this is true but on a shower/tub combo valve does the shower side of the valve flow at a lower rate then the Tub side? Or is the restriction in the shower head only?
    thanks
    C
    Some brands do in fact put a restrictor in the outlet to the shower. It is to help insure that when in the "tub" mode no water goes up to the shower.
