greyhound1
I hope that this is the right section for this. As a 49 and closing in on 50 year old I know the risk in knowing just enough about a topic to get you into trouble. I live in southeastern PA and am having a propane gas installation. Black iron pipe will be installed in my basement for a dryer, stove and possible future house heater and water heater. We have oil heat now. This question relates to the inside work only. A 16" main consisting of 3/4" galvanized pipe will enter through my masonry block. Only black iron pipe will be used on the inside (1/2" legs to the stove and dryer). Brass ball valves will be used at various points along the pipe (at main and at each present appliance and for future applications, as stated above)
My questions are:
1. Can galvanized pipe sit against masonry block (later to connect to the outside regulator) and be exposed to outside elements without or should a sleeve be put through the insertion hole "for protection"? if a sleeve is required, should it be plastic or can it be some other material? (Someone mentioned a copper sleeve but my information tells me that the copper would react with the galvanized and corrode it);
2. Can galvanized be joined with black iron without causing a galvanic reaction (my thoughts are that they are both steel and not dissimilar metals)? Also, should dielectric couplings be used between the galvanized and black iron? I've read many opinions that galvanized should never be used with propane because of the possibility of flaking zinc damaging the appliances. Is this still an issue?;
3. Should dielectric couplings be used between the brass valve and black iron? Is it overkill to use these couplings at both ends of each valve? Is it beneficial? Is there a downside? I'm thinking that I would like to do this for my peace of mind;
4. What material should the fasteners, screws, fastening straps, bands and brackets be against the black iron (carbon steel? galvanized? Any suggestions?)
5. Is it common to have a drip tube at the dryer (I've mostly seen flex tubing directly at the bottom of the black iron and no drip tube).
6. Should a dielectric coupling be in between the black iron and flex tubing?
Any other Southeastern Pennsylvanians know whether this hookup is proper (i.e. code)? I intend to ask these questions to the local building inspector (eventually, when he returns my call!)
Thank you for all of your assistance.
My questions are:
