Results 1 to 8 of 8
Thread: Question about removing valve (Fleck 2510)
    DIY Junior Member chargedmr2's Avatar
    Jul 2010
    TX
    Default Question about removing valve (Fleck 2510)
    Quick question:
    I'm installing a new 2510 water softener and after filling the media tank with resin I put the control valve on. After doing so, I remembered that I should fill the tank with water to reduce the amount of air in the lines when the system goes live. I removed the control valve, added water, and screwed the valve back on.
    Now to my question--should I have taken the resin out and made sure that the distributor tube was seated all the way down to the bottom before putting the valve back on??
    I read on this forum that removing the control valve means that the resin needs to come out as well, otherwise the distributor tube may have risen (from pulling the valve off) and then could break when the valve is screwed back on due to resin getting under it and causing too much pressure on the tube as the valve tightens down.
    The last thing I need is resin in my water lines!
    Dec 2009
    Alaska
    Did you put gravel down at the bottom of the media tank?
    When you put the valve back on the tank was the distributor tube above the threads of the tank?
    If the tube was not above the top of the threads then no worries...
    If it was just a little say 1/4" then also I would not worry..
    Jul 2010
    TX
    The tube was about even or maybe just a hair over the threads--nothing noticeable anyway. I have only resin, no gravel in the tank.
    Everything is ready to go, except that I can't find 3/4" ID PE drain tube anywhere.
    Dec 2009
    Alaska
    Watts 1/2 thread to slip.... then 1/2" poly tube with a tube insert...
    The watts is at like home depot along with the other 2 items.... what would work for your drain is that is what you are working on.
    Jul 2010
    TX
    My drain line needs to be fairly long (about 35') to run from valve down to floor across length of garage, back up about 5' and then through a wall into the laundry room to reach washer drain. I've read that 1/2" is not large enough for this run. I think Fleck manual actually says to upsize from 1/2" on runs longer than 20'. Home depot near me only has the 3/8 ID PE drain tube. Is 3/4" PE really that uncommon at hardware/plumbing places?
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    You can use 3/4" PVC for the run.
    Jul 2010
    TX
    Bob,
    Would PVC be ok even if I had to incorporate quite a few elbows? It's not exactly a straight shot to the drain since I have to pass though a wall as well as cabinets--I would probably need 5 elbows in the run.
    Jul 2009
    Pennsylvania
    Quote Originally Posted by chargedmr2 View Post
    Bob,
    You will be fine with 5 elbows.
  1. Fleck 2510 Salt Dose
    By qpm in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-11-2011, 06:16 AM
  2. A few Fleck valve questions and sizing help
    By tmp9a59 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-28-2010, 07:40 PM
  3. Problems with my fleck valve, clicking noise
    By acrod in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-11-2010, 09:49 AM
  4. fleck 5600 valve
    By mywater in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-26-2009, 09:41 AM
  5. Fleck 5600 Valve Problem
    By filadajunk in forum Plumbing Forum Discussion & Blog
    Last Post: 12-17-2007, 09:52 PM
