Results 1 to 12 of 12
Thread: sealing off unused WH drain?
    DIY Junior Member hamlet's Avatar
    Jul 2010
    dc
    Default sealing off unused WH drain?
    Hello all,
    I am doing a gut renovation on the lower level of my condo and have a question- In the rear of my kitchen was my old laundry/water heater room. The water heater had a drain (?) pipe extending up through the floor which was met by a copper drain pipe coming from the water heater istelf (I am attaching a photo because I am sure I am not explaining this correctly)
    We relocated this water heater to another part of the house, and the plumber who did the work for me cut this old pipe (ABS pipe, about 2" diam?) down to floor level (tiles removed) and said that he had sealed it off from underneath when they were doing other work under the slab adding drains in the new locations of the laundry and a new shower in the bathroom I do not smell anything coming from the pipe, although sometimes I swear I can feel cool air coming up from it, but I have to assume he did what he said.
    Here is my issue- This area is now going to be part of the kitchen, which is going to be covered in engineered wood or laminate. Before I do that, I will have the floor leveled with a self leveler, but I need to block this drain closer to the surface so that I am not pouring a whole bunch of leveler down it until it reaches floor level. (not to mention that if this pipe is NOT sealed off (and considering what a crappy experience I had with this contractor, I would not be surprised if it was not sealed), I don't want cement going down drains it should not be going down.
    So... Can I use some sort of expanding plug to permanently seal this off below the surface so that I can cement over it with the leveler?
    If anyone has links to or names of specific products, that would be great.
    Thank you all, and I hope what I wrote makes sense to someone!
    Jan 2006
    Rosedale, Md
    If you can feel cold air comming up the pipe there's a good chance it's not sealed off. I would glue a cap on it; you will have to cut it down below your finished floor.
    http://www.hardwarestore.com/media/p...3_front100.jpg
    Jul 2010
    dc
    Thanks, Shacko
    So you mean break the concrete up around the pipe and then cap it below floor level? What about just putting a mechanical test plug down in there and then concrete over it? That would eliminate having to break the concrete up to seal it off?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    JUST MAKE SURE IT IS CUT FLAT TO FLOOR ,
    AND GLUE IN ON THE INSIDE A PLASTIC TEST PLUG !
    SUCH AS THIS
    http://plumbing.hardwarestore.com/52...ap-612335.aspx
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Aug 2007
    You might also check around the outside footings that pipe should exit there and you might
    want to add a plug at that end also to prevent small rodents from making nest inside the pipe
    MACPLUMB 777
    E-MAIL
    Jan 2006
    Rosedale, Md
    A mechanical test plug may protrude more then the cap, you only have to cut it down to where the top is below the floor, I don't like the test cap the other post suggested, they don't give enough glue surface. Make sure when you put in your floor nobody pokes a hole it it, your call.
    Jul 2010
    dc
    Thanks again, Shacko
    I see what you are saying. I am also not a fan of the test cap mentioned above- looks flimsy and not much area there to glue to.
    Looks like my best bet is to try and break up some of the 30yr old concrete just around it so I have room for the cap.
    The inspectors here don't allow the test cookies permanently. They do allow caps or mechanical plugs.
    Use a "TopKap" cleanout fitting. It glues into the pipe with a flush pipe plug in it. You have to cut the pipe slightly below floor level to accomodate the "lip" of the fitting, but it does not have to be a smooth cut, since the seal is to the inside of the pipe, not the rim.
    It looks like that copper pipe is for the pressure relief valve, not really a drain just a diverter in case steam or hot water ever comes out. It probably terminate outside with an open end and that's why you can feel cold air coming through.
    Jul 2010
    dc
    Terry- thanks for the info- its a crapshoot with the inspectors here. Each one seems to have his/her own "interpretation" of the code- very frustrating!
    Thank you, HJ- that sounds like exactly what I'm looking for- I will check that out!
    Bpetey- I think you are right. Even if that is the case, I need to seal it off before I pour leveler on the floor.
    Thanks again!
    Journeyman/Inspector Inspektor Ludwig's Avatar
    May 2006
    In the good ol' UPC
    Yeah, it's probably just an overflow drain to the outside. If you can verify that it's not connected to the sewer then I would do what's called "dynamiting" the drain. I prefer this method to caps on an abandoned line that can't be removed. God knows that some ding dong will come along and find a drain pipe, remove the cap and connect who knows what to it. Cut the pipe flush with the floor then wad up a bunch of newspaper and shove it down the pipe below the floor level and fill it with grout.
  1. Proper way to cap unused dedicated dishwasher drain
    By do it right in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2008, 03:45 PM
  2. Sealing around drain
    By Nate R in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2008, 07:56 PM
  3. removing unused drain + supply
    By snapplez in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2007, 12:33 PM
  4. trying to unclog old unused drain in slab
    By blues1360 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-15-2006, 12:56 PM
  5. Trap primer needed on unused floor drain?
    By karsc01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-02-2006, 09:11 AM
