Results 1 to 5 of 5
Thread: High pressure from spout bad from shower head
    DIY Junior Member terrypnt2001's Avatar
    Jul 2010
    Colorado
    Default High pressure from spout bad from shower head
    Ok last question for now.
    the water pressure in my bath tub would blow you away!!1 but when I pull the knob and switch it over to the shower head the pressure is about a 1/4 of the spout pressure.
    A fix?
    Dec 2007
    Unscrew the showerhead from the shower arm and you will know where the problem is.
    Jul 2010
    Colorado
    I am a girl and not a plumber at all so could you tell me what I am supposed to see?
    Dec 2007
    When you unscrew the showerhead so there is just the chrome 1/2" pipe sticking out of the wall and you turn it on with water supposed to be coming out of the shower you will probably see a great flow of water.
    Then you will know the shower head is clogged.
    Showerheads have restrictors in them that sometimes plug up.
    Other times soaking the showerhead in vinegar or CLR can clean them out.
    If you don't see a good amount of water then there is another problem and it involves repairing the valve.
    Jul 2010
    Colorado
    Thanks so much for getting back to me so quick I will do that.
  1. Shower head flows whether tub spout diverter on or off - please help
    By bz9000 in forum Shower & bathtub Forum & Blog
    Last Post: 04-19-2010, 07:55 AM
  2. How high can I mount shower head
    By newmex999 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-15-2010, 03:00 PM
  3. Shower Head/Spout Leaks after remodel
    By rjboykin in forum Shower & bathtub Forum & Blog
    Last Post: 08-20-2008, 03:43 PM
  4. OK for shower head but not for tub spout?
    By OldPete in forum Plumbing Forum Discussion & Blog
    Last Post: 04-20-2007, 05:42 AM
  5. High Head Pressure
    By bigringbk in forum Toilet Forum discussions
    Last Post: 03-02-2005, 03:33 PM
