The house I own has too few sprinklers on each zone and too many zones. We have great water pressure and I have tested several zones on at the same time. A landscape friend says I can easily combine some zones with a "T" fitting into 1 valve. I am about to replace the older valves as well since they are ~20 y/o and starting to die.
the lines come into the box direcly into the valve (barbed male end on valve) so I need to change direction of the lines first. Anyway the only way I can think of to combine 2 lines into 1 valve (1" pipe into a male barbed end valve) is to use an elbow for each of the 2 lines to change direction (90 deg) then use a small piece of hose (for each eblow) and then use that to connect to a "T". I can then run a small piece of hose off the single side of the "T" to connect to the barbed valve end.
Essentially I am creating a football goal post.....and I don't find any fitting like this anywhere so suspect I am stuck with this creation.
Thoughts?
Thoughts?
