Results 1 to 4 of 4
Thread: How Long Will One Last?
    DIY Senior Member tvl's Avatar
    Jul 2006
    South Carolina
    Default How Long Will One Last?
    I'd like the thoughts of some of you "seasoned" professionals:
    I have a water well which was dug in 1978. At the time of installation a Square D 40/60 pressure switch was installed near the tank which is underneath the house about 80 feet from the well itself. This setup has functioned flawlessly for 32 years (this well is used only for the sprinkler system, washing cars, washing house, etc.). The only things I have replaced during the 32 years were:
    1- about 1988 I installed the older type water tank with a captive air tank
    2- about 1985 I replaced the 1 hp pump
    3- in 1995 I replaced the 1 hp pump again (it's still running)
    But, I'm curious about the pressure switch. It's never been replaced! It just keeps working. How long do these things last?
    What is the likelyhood of the pressure switch contacts sticking and the pressure building to a point where some damage is done? Even if I replace the switch, a new one could still fail prematurely. After 32 years, do I just let it go OR is some preventive maintenance in order?
    Your thoughts and suggestions are appreciated!
    TVL
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    That switch is probably better than any new one you could purchase. They made things better back then. Just make sure you have a pressure relief valve in the system and don't fix it if it's not broken.
    Jul 2006
    South Carolina
    Quote Originally Posted by valveman View Post
    Thanks ValveMan!
    Well. I do NOT have a pressure relief valve in my system ............... that's what got me to thinking. Would you be willing to recommend a relief valve or post a link to a good one?
    My pump cuts out now at approximately 58 PSI. What PSI rating relief valve should I get for my system .......... 75 PSI (more or less) ???
    I will get one installed pronto!
    Thanks again!
    TVL
    Mar 2006
    Lubbock, Texas
    75 PSI would be good. You can get one for about 8 bucks at any home improvment store.
  1. How long do tanks usually last?
    By wbw in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-28-2010, 01:49 PM
  2. Just how long will a furnace last?
    By Ian Gills in forum HVAC Heating & Cooling
    Last Post: 01-14-2008, 04:52 PM
  3. Can we do this? (sorry it's long)
    By Grandma Lewis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2007, 07:17 PM
  4. Anode Rod-Sorry--Long
    By pthomas2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-04-2006, 12:04 PM
  5. Took the plunge(r) - long
    By jgc in forum Toilet Forum discussions
    Last Post: 08-05-2005, 04:12 PM
