Results 1 to 15 of 36
Thread: Parallel wiring for dehumidistat in bathroom
Hybrid View
    DIY Junior Member tomtbone's Avatar
    Feb 2010
    tomtbone in Boston
    Default Parallel wiring for dehumidistat in bathroom
    Just want to make sure this is the correct schematic for what I am doing.
    I am installing a dehumidistat in the bathroom for the exhaust fan along with a switch. I want either/or to be able to turn it on.
    i.e. Turn on the fan with the switch when you first get into the bathroom before you start taking a shower. You turn on the shower and the dehumidstat closes its part of the circuit. I'm done with the shower and I turn off the switch, but the fan is still running because the dehumidstat is still closed. Eventually the fan will turn off once the humidity level has gone down. I basically just want them to run independant of each other and not interfere with each other. Is this diagram correct?
    Conceptually, yes, it is correct. But, with the electronics in the humidistat controller, it may need neutral to be wired to it, and may not like the by-pass on-off switch. You'd have to read the specifics of that switch. If the humidistat switch was entirely mechanical, then yes, it should work, but it may have electronics which would need power. It would normally say if it needed neutral. You may have to call the manufacturer to verify it wouldn't be damaged by power on both ends when it wants to be off unless it says something in the tech sheet.
    Jun 2007
    North Carolina
    It looks like the humidistat is wired in parallel with the switch and series with the exhaust fan.
    If this is true then neither of the appliances will last very long as one of then will burn up due to low voltage.
    Feb 2010
    tomtbone in Boston
    Well I have read in multiple places online of people using this with another switch so that they can have manual and automatic operation. I'm just trying to figure out the best way to wire it that way.
    quote; If this is true then neither of the appliances will last very long as one of then will burn up due to low voltage.
    You could have as many switches as you want wired in parallel as long as you remember which one to turn off again. And ALL switches are wired in "series" with the device if you expect it to operate the appliance. NEITHER situation changes the supplied voltage.
    This will probably work. But, as I indicated, some switches (those that have electronics in them) often need a neutral attached for them to operate. It may or may not like having power on both ends of the switch when the parallel path is energized, but it may not care. You may want to look for an integrated humidistat switch that would let you do what you want with one device, rather than guessing if it would work with two. What brand and model are you thinking of? Have you read the spec sheet for it? It may even have a diagram of how to do exactly what you want. There should be no problem with series voltage drops wired the way you have it. The only issue is if the switch would actually function without a neutral, and if it would survive with power applied to the output when it is trying to open to shut the device off.
    Jun 2007
    North Carolina
    But should you wire an electronic switch in series with the bath fan one or the other will let it’s smoke out and we all knows that it ain’t gonna work without its smoke.
    If this switch is a mechanical switch then it is going to be rated in volts and amps.
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    Quote Originally Posted by tomtbone View Post
    As has been said, what you are trying to do will work just fine as long as your switches are mechanical -- two black wires only (plus maybe a ground screw (green)) -- and not electronic. And if your regular fan switch is a timer, it will have to be a spring-loaded twister in order to not be electronic.
    Feb 2010
    tomtbone in Boston
    I received the dehumidistat in the mail today. It seems to be pretty straightforward with just two black wires in the back to connect inline. I think this should work with that first diagram. I'll probably hook it all up before walls are closed and such. This is the one I got and here are the instructions that came with it.
    Ranco J10
  1. Broan DH100W Dehumidistat contol
    By tomtbone in forum HVAC Heating & Cooling
    Last Post: 02-23-2010, 12:19 PM
  2. wiring in bathroom
    By web_surfer in forum Electrical Forum discussion & Blog
    Last Post: 07-31-2009, 08:40 PM
  3. bathroom wiring; one circuit?
    By thegallery in forum Remodel Forum & Blog
    Last Post: 09-28-2008, 09:11 PM
  4. Wiring Diagram for Bathroom
    By nelsonba in forum Electrical Forum discussion & Blog
    Last Post: 12-03-2007, 08:28 PM
  5. Bathroom and Closet Wiring
    Last Post: 11-06-2007, 09:22 PM
