Thread: Mis-Reading the Code
    DIY Member Bassman's Avatar
    Aug 2006
    Ventura, CA
    Default Mis-Reading the Code
    I'm looking at the CA Plumbing code and it says:
    706.1
    "Changes in direction of drainage piping shall be made by appropriate use of approved fittings and shall be of the angles presented by a one-sixteenth (1/16) bend, one-eighth (1/8) bend, or one-sixth (1/6) bend, or other approved fittings of equivalent sweep."
    I can't figure out why a right angle is not included in this list. Are there no 90 degree bends in drain pipes? Thanks for any help.
    Neil
    You would combine two 1/8" bends.
    A long sweep 90 is equivalent, the same as an 1/8 bend and street 1/8 bend put together.
    Of course there are, but the actual application determines WHICH 90 can be used.
  1. rain dial timer reading short
    By jfissella in forum Irrigation / Sprinkler Forum
    Last Post: 11-14-2009, 02:29 PM
  2. Is This Up To Code?
    By Briandl in forum Electrical Forum discussion & Blog
    Last Post: 09-05-2008, 07:49 PM
  3. Code
    By worker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2007, 05:38 PM
  4. Is this within code?
    By pitterpat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-04-2005, 12:47 AM
  5. reading my polybutylene pipe date
    By kdclues in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2005, 07:56 AM
