Results 16 to 30 of 31
Thread: Kenmore Ultra0Soft 200 or 250 Shutting house water off.
  1. #16
    [QUOTE=Wally Hays;265251]
    Say what!
    All residential control valves have an internal hard water by pass meaning that if you use water during a regeneration you get hard water, not no water
    Quote Originally Posted by Wally Hays View Post
    SAY WHAT! Did I say "control valve"? or were you just inferring things as usual.
    Well lets see.... we were talking about a water flow problem with a water softener and you said;
    Check your service manual but it sounds like the valve is stuck.
    Now a softener has a service manual and I don''t know of anything else in the conversation that has one but correct me by telling us what service manual, and "valve" you were referring to if not the softener manual and the softener's control valve, which is actually mostly a control valve service manual.
  2. #17
    You're welcome Ron, and thanks for your service.
  3. #18
    In the Trades Wally Hays's Avatar
    Nov 2009
    Go away, your entire purpose in life is to argue with people and start trouble. Get a life or get out
    Perception is 3/4 of reality
  4. #19
    Say WHAT!!
    Man you're getting emotional again.... Step away from the adult beverages earlier in the evening and then get more sleep and I promise you'll feel better.
  5. #20
    Nov 2009
    I'll back off the adult beverage when you back off the crack pipe
  6. #21
    How about you tell us more about what you meant with your statement about a stuck valve on a water softener.
  7. #22
    Nov 2009
    What, you don't want to back off the crack pipe?
  8. #23
    How about fight this out in private messages...my personal feeling is most of this is nit-picking, and not reading the intent of a post, rather than exactly what is said. Often, there is more than one way to view an answer...you just seem to have to always take it different than was meant.
    There is good info coming from both sides...but, negativity does not help anyone.
  9. #24
    Nov 2009
    Yes indeed that would be the logical, professional and courteous way to go about things but unfortunately, certain individuals would rather argue with everyone and anyone that might have a differing opinion, experience or point of view, including quite often the OP, but short of everyone leaving or kissing this certain persons butt there seems to be no solution to the problem. After all, how do you argue with "God"
  10. #25
    DIY Junior Member extremewatersystems's Avatar
    Jul 2010
    Somerton, AZ 85350
    check if you do not have resin beads in your pipes The distributor tube mite have broken inside the resin tank.
  11. #26
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    How about fight this out in private messages....
    Unfortunately priviate messages are disabled on this board and have been for some time.
  12. #27
    Then why don't you do that instead of all the personal name calling attacks?
    You make the decision to type what you type, no one else does that for you.
    Sizing and programming a water softener is done with very simple math. Not opinions or points of view.
    The math and formula used are both very simple.
    I have used both for many years and have the formula and examples of the math used on my web site for anyone to use. Or, you or anyone else can prove me wrong using resin manufacturers' data instead of as you say, opinions and differing points of view.
    Here in this and other forums, with the exception of the constant SFR sizing of a softener, Bob999 uses the formula and math. He is the only one that does. And you don't see me saying anything about the K of capacity or salt dose he suggests. IOWs, there's no argument because he is right; he's looked it up and not stating an opinion.
    You and others here don't use the formula but then you don't size for anyone. You post about me and rarely say anything more than a short sentence to the OP if that; it's all about me and what I say and how I say it etc. etc..
    The point is that using math and proving your point by backing it up with resin manufacturers' data etc. isn't arguing unless you don't understand how to use the manufacturers' data or spec sheets.
    BTW, I support no PMs here or on other forums because no one else can learn from a PM except the recipient and if you can't say something in public, I don't think it belongs in a PM either.
  13. #28
    Nov 2009
    Many many times math has been used here and on other threads and you have disputed it. Even when the math comes from engineers with degrees in such things so I see little point in arguing "math" Many times the point has been backed up using the manufacturers data and you manage to dispute that also. In other words its a no win situation unless we all agree with you which we don't always. As for PM's, are we to believe that you have never PM'd anyone else here ore elswhere? The PM feature is a convieniance not a necessity.
    And to set the record straight here it was you that began the name calling with the "alcoholic beverage" comment but then, when I go back through the threads, 90% of the time it is you that starts the name calling and arguing.
  14. #29
    Wally,
    It isn't worth it. Stay on track and respond only to the OP's question. You have valveable info to share as we all do.
  15. #30
    Nov 2009
    Thanks for the reminder Skip.
  1. Shutting off water for winter?
    By Bigmamma in forum Toilet Forum discussions
    Last Post: 10-22-2009, 02:39 PM
  2. hot water shutting off
    By handijoe in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2009, 11:10 AM
  3. Shutting down the house question - in a hurry
    By bojala in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2008, 01:46 PM
  4. Shutting off one of two water heaters?
    By DocD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2006, 11:19 AM
  5. No water - pumptec not shutting off
    By CindyM in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2005, 06:20 AM
