Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Kenmore Ultra0Soft 200 or 250 Shutting house water off.
    DIY Junior Member Airborne16's Avatar
    Jul 2010
    Fort Hood, Texas
    Default Kenmore Ultra0Soft 200 or 250 Shutting house water off.
    My 7 or 8 year old Kenmore UltraSoft 200 (or 250) water softener appears to have shut my house water off, all of it. No toilets, sinks, fridge water dispenser, nada. I've confirmed at the street (main water valve) that the main source is good but the old water softener seems to be the culprit. I've unplugged the cord and replugged it in. I've pushed the re-cycle buttons, to no avail. What am I missing? Thanks. 254-220-3806. Ron (Airborne16)
    In the Trades Wally Hays's Avatar
    Nov 2009
    Check your service manual but it sounds like the valve is stuck.
    Perception is 3/4 of reality
    If it doesn't have a by pass valve, you cut it out of the plumbing and put the plumbing back together but.... how did you determine that it is the softener? More likely is a gate valve gate broke and closed or a washer came off a washer type valve and the gate or washer is blocking water flow.
    But it could be a blocked top or bottom basket in the softener is blocked up but that is a very rare thing that has to have a cause that comes in with the water. Has your water been dirty lately? Do you have a well or city water. With city water I can't guess what could block a softener.
    BTW, if you unplug the softener, it can not do a regeneration because there is no power to move the valve parts so it is just going to sit there not even knowing you pushed any buttons. It's like taking your battery out of the car or disconnecting it and sitting there turning the key to Start, On etc. and pushing the window and door lock buttons, and nothing happens.
    Quote Originally Posted by Wally Hays View Post
    Say what!
    All residential control valves have an internal hard water by pass meaning that if you use water during a regeneration you get hard water, not no water.
    Jul 2010
    Fort Hood, Texas
    Thank you for the input. No, I did regeneration after it was plugged back in and nothing has changed. The brine valve isn't stuck; slides freely on its track. What other accessible valve might there be that I could troubleshoot? My Kenmore 250 (NOT 200) has a by-pass PVC valve that slides in and out for servicing purposes. I've pushed it in and out; still no house water. Its Saturday now; no Sears Kenmore repairman til Monday at soonest. Just thought I could tinker around with it myself and get it running. Good thing my wife's away this weekend!
    There is no other valve in a softener.
    You didn't answer my questions about what makes you think it is the softener and not a water shut off valve?
    Jul 2010
    Fort Hood, Texas
    Oh, sorry. I think its the softener because this same unexpected water shutoff occurred 2 weeks ago. We troubleshooted the water softener and the house water came back on within minutes. That does NOT necessarily mean there's a cause and effect. The city water company confirmed it was not a problem on their end of the meter. My water main at the meter splits into an inground sprinkler system (which is working fine right now....just tested it) and the main house intake which runs through the water softener. I don't know if I need a plumber or a Sears water softener technician. The in-house water worked fine a midnight last night. By 7 a.m. today not a drop through sinks or toilets. Hmmmmm.
    Jul 2010
    Fort Hood, Texas
    Oh, sorry. I think it might be the softener because the same thing happend 2 weeks ago. After troubleshooting the water softener the house water magically came on moments later. That does NOT necessarily mean cause and effect; maybe coincidental. The city water company confirmed the problem lies between the street-side meter and my house; not their problem. The meter splits my water into two usags: my yard sprinkler system (and its working fine even as we speak), and into my house via the water softener. I had house water usage at midnight last night and not a drop by 7 a.m. today. Not sure if I need a plumber or a Sears water softener technician. Thks for the comeback. Ron
    Dec 2009
    Alaska
    Is there a bypass on the unit that you could change from service to bypass?
    treated to untreated?
    Jul 2010
    Fort Hood, Texas
    Yes, and either way I've pushed it, it still hasn't triggered anything. No agua either way.
    Either the bypass has broken or as Gary said, something else in the system (house, not necessarily the softener) is clogged. Gate valves when they fail can cause this, as can those with washers that fail.
    Dec 2009
    Alaska
    Quote Originally Posted by Airborne16 View Post
    With it in bypass or in service there is no Water?
    If this is the case then find the valve just before the softener to make sure that it is open, I have seen a ball valve that is just before a system get turned to the off mod and no water into the house..
    Turn the main water valve off, depressurise and remove the bypass stem. Turn water on to make sure it's getting to the unit. Check for a bad oring on the plunger.
    Nov 2009
    [QUOTE=Gary Slusser;265156]Say what!
    SAY WHAT!
    Did I say "control valve"? or were you just inferring things as usual.
    Jul 2010
    Fort Hood, Texas
    Team, the mystery is solved. I repiped my city water into my house BI-PASSING my water softener, and I STILL had no water flow...until I gently tapped my exposed PVC pipes. The tapping dislodged the blockage at the heart of my mystery. Calcium build-up, sediment, or something. My softener had been off for a couple of months due to a minor problem it was having, and that must've been enough hardwater to build up a blockage, the one 2 weeks ago and the one this weekend. I'm repiping my watersoftener back, exactly as it was, re-reading the user manual for the umpteenth time....and even then probably still having a Sears technician out this week to ensure it is operating correctly. I appreciate your contributions, Wally, Gary, Skip, Jim, and my friend in Alaska. My wife thinks I'm a blogg nerd but I was impressed by your knowlege and quick willingness to walk with me through this challenge. Ron...Airborne16
  1. Shutting off water for winter?
    By Bigmamma in forum Toilet Forum discussions
    Last Post: 10-22-2009, 02:39 PM
  2. hot water shutting off
    By handijoe in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2009, 11:10 AM
  3. Shutting down the house question - in a hurry
    By bojala in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2008, 01:46 PM
  4. Shutting off one of two water heaters?
    By DocD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2006, 11:19 AM
  5. No water - pumptec not shutting off
    By CindyM in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2005, 06:20 AM
