Results 1 to 7 of 7
Thread: Water Heater Inspection - Drain Valve Angle Question
    DIY Junior Member luckycharmz336's Avatar
    Jul 2010
    AZ
    Default Water Heater Inspection - Drain Valve Angle Question
    The water heater drain valve angles about 2 inches up hill from the water heater to the wall, the inspector said this is an issue and safety hazard. How concerned should we be able this? Below is a picture
    We want to have it fixed if it is a major issue, however, if we shouldn't be concerned I don't want to force them to change it. Thanks
    Cut the wall and lower the 90 in the wall.
    Below is my favorite exploding water heater video.
    In the Seattle area, a water heater shot though a garage roof and landed blocks away.
    In the Trades jnaas2's Avatar
    Mar 2009
    Evansville In
    where is the line going to
    Plumber jimbo's Avatar
    It is a fairly serious problem. Almost guaranteed that as time goes by, some drippage will occur from the valve, or some condensation will occur in the line. This water will sit right there at the relief and leave mineral deposits, clogging the valve. It might not work when it needs to.
    Somewhat shocking that it is done this way.....obviously no permit because the inspector would still be looking for a big enough crayon to write NO WAY.....all over the papers!
    Dec 2007
    It is a definite FAIL...
    It will cause the reliability of the T&P valve to suffer and could result in a hazardous condition....
    The easiest way to correct it is to place some concrete blocks, or a few circular concrete stepstones, under the heater to raise the valve above the opening in the wall. That corrugated connector is also "illegal" in most areas. Use copper tubing to connect the SAFETY valve, (not a DRAIN valve), to the pipe at the wall. In Phoenix, the heater landed a block away, and the house had to be demolished because it was not repairable.
    Dec 2007
    Sorry to see that you have a Whirlpool Energy Smart water heater as well....
  1. Low pressure electric water heater after sprinkler inspection
    By randy Boston in forum Water Heater Forum, Tanks
    Last Post: 11-04-2009, 07:24 PM
  2. Water heater inspection...
    By thinkly in forum Water Heater Forum, Tanks
    Last Post: 05-29-2009, 11:40 AM
  3. neo angle shower drain question
    By johnnyhomeowner in forum Shower & bathtub Forum & Blog
    Last Post: 04-24-2008, 04:51 AM
  4. Question on planning for inspection and floor drain
    By camerono in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2006, 10:25 AM
  5. direct-vent gas-fired water heater inspection.
    By canton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2006, 02:53 PM
