Results 1 to 9 of 9
Thread: Drain cleaning using a snake and a high pressure water jet a friend lent to me
    Jul 2007
    USA
    Default Drain cleaning using a snake and a high pressure water jet a friend lent to me
    I have booked a local plumbing firm to clean my drains, some of which have become slow.
    What can I expect?
    I have 1950s cast iron pipes with only one clean out on the main stack that is probably stuck solid.
    I have a floor drain they could go through.
    What exactly will they do?
    And will it make any difference?
    Dec 2007
    Ian if they need to get that stuck cleanout plug out it will only take a second with a hammer and chisel...
    They will examine the symptoms and determine the best way to gain access to the plug and take care of it for you...
    Thats what they are paid to do... How long of a guarantee do they give you? did you ask?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Any good plumber or drain cleaner will know all about how to remove or cut out old frozen
    clean out plugs, or to remove and reinstall any p traps as needed to get access to be
    able to run power snakes though drains to clear out crud buildup sticking to pipes
    and i am glad you are doing this without using harmful drain cleaners
    what you might do is ask for some type of flat price to snake out all the drains at one
    time many company's have such a price that makes it cheaper then a drain by drain price
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    You can expect that they will know HOW to clean the drains properly, although I prefer to clean drains when they are "stopped" not "slow", in most cases.
    Jul 2007
    USA
    That's the issue HJ. Most of my drains are slow and none are stopped so I am questionning how they will propose to do the work.
    I define a slow drain as one that does not clear a faucet on full.
    British drains do that with ease.
    Aug 2007
    Ian you and i agree !
    Whenever i finish clearing a drain i fill the sink to the top and with the water running
    full out i open the drain and i expect it all to go down in a few seconds that is how
    i test to make sure i did a good complete job !
    MACPLUMB 777
    E-MAIL
    Jul 2007
    USA
    Right, I had my tub, vanity, kitchen and laundry tub snaked. They clear better now.
    But the floor drain outside the basement now backs up when the washer discharges.
    What now?
    Clear that drain also.
    Jul 2007
    USA
    I am going to buy my own snake after this one is done.
  1. High water pressure
    By lennyk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2010, 04:48 PM
  2. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  3. Water Pressure too High
    By topoman92127 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2009, 06:39 PM
  4. High water pressure
    By At Sea in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2009, 07:41 AM
  5. High Water Pressure
    By Mikeyboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2008, 09:19 PM
