Results 1 to 3 of 3
Thread: Blocked floor drain looks corroded?
Hybrid View
    DIY Junior Member stephced's Avatar
    Jul 2010
    il
    Default Blocked floor drain looks corroded?
    our basement floor drain is clogged with what looks like rust and rocks (concrete) and water just sits on the floor...not the average hair, slime and soap scum. Have you ever heard of this?
    At one point it would at least drain slowly. Now it won't drain at all. Trying to dig through it with a stick/pole gets us now where becuase the grit, water and rocks fall right back in like quick sand. Could the drain itself be falling apart? The rim seems corroded and broken and the water is rust colored. Seems like an auger wouldn't as much as some sort of vacum/suction would. Tried plunging it and that doesn't not work either. Is this a job for a professional?
    Dec 2007
    Probably is...
    If you are facing problem with drain pipe blockage or anything similar like that then the best way is to look for the drain cleaning service providers available to help you out in getting the drain cleaned in an environmental friendly manner. So, if you are planning to get it cleaned then look for the service providers available online.
  1. Kitchen-washer cast iron drain is corroded
    By pachi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2010, 07:39 AM
  2. Easiest way to deal with a corroded drain at floor slab?
    By SmallSea in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2007, 06:30 AM
  3. Washer drain pipe blocked
    By carimwc in forum Drain Cleaning
    Last Post: 10-17-2006, 09:01 AM
  4. Corroded Tub Drain
    By phxrt in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2006, 12:04 PM
  5. shower drain cover corroded
    By rauenzahn in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2006, 02:54 PM
