Results 1 to 2 of 2
Thread: leak at bypass valve assembly
    DIY Junior Member Mikegranado's Avatar
    Jul 2010
    san antonio texas
    Default leak at bypass valve assembly
    I have a GE Smartwater, the by pass valve assembly is leakng from where it connects to the body valve. I interchanged the 0 rings but the same valve keeps leaking. Do I need a new assembly or should I put a bigger 0 ring. Do not know what else to do here. Any advice would be helpful.
    Replace the bypass. Nothing you do will stop the leak unless you change the bypass.
  1. leak due to overflow hole in drain assembly
    By NYCremodel in forum Plumbing Forum Discussion & Blog
    Last Post: 08-02-2009, 08:55 PM
  2. Boiler bypass using mixing valve??
    By HandyManDan in forum HVAC Heating & Cooling
    Last Post: 02-21-2009, 01:21 PM
  3. Water Softener Bypass Plug Leak
    By sasha7771 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-09-2008, 07:58 PM
  4. shower screwdriver stop assembly leak
    By CluelessInSeattle in forum Plumbing Forum Discussion & Blog
    Last Post: 05-10-2007, 07:25 PM
  5. Culligan Bypass Valve
    By hammy233 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-07-2006, 04:15 AM
