Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Any problems with this bathroom layout?
    Default Any problems with this bathroom layout?
    This is the upper level of a two story, and bathroom remodel.
    The toilet will be turned so that the tank is along the right wall. The door into the master closet (bottom right) is now 32", and the shower has been move over maybe by 6". I will like to install a 6' tub and not 5' as shown in the drawing.
    As Dolly Parton once said, "It looks like you are trying to put 10 gallons of mud into a 5 gallon bucket". At the very least I would rotate the toilet so it is under the shelf unit. And that door next to the shower looks like it will have to be LESS than 2'-0" to fit into the space which makes it almost useless.
    DIY Member jadziedzic's Avatar
    Aug 2006
    New Hampshire
    Exchange the position of the (turned) toilet and shower; that will give you more room for the entry door. A two foot door may not even by allowed by your local building code.
    Talking
    ok, I did mention that the toilet was going to be rotated, and the door was going to be 32 inches. I guess I should of redrawn the entire diagram to scale before posting. Oh, that shelf unit is no more.. lol..I did write 32 on the diagram but it came out so so small..
    Quote Originally Posted by jadziedzic View Post
    The entry door is now 32", I should of erase the orignal 2' before posting. Did mention it though - anything else? Thanks for the answeres.
    Default this is what I should of originally post...
    now shower the toilet turned, and the bottom door label 32 " wide
    The door would be better placed between the shower and the toilet.
    That would also allow for a much larger shower.
    Terry on the original design, that is exactly how it was done. And where the door is now, was originally designed for storage and small TV. Wifey didn't like the idea of having to go through the toilet to get to the bath. I tried to talk her into it, but she wouldn't go for it.
    Terry or anyone - as someone else above suggested, and my wife sort of hinted to, would it be wise to flip the toilet and the shower from a functional standpoint. This is the rear corner of the house with a window - trying to paint the picture here. Top right hand corner in the below pic.
    Should the toilet be closest to a window?
    The only hassle with any plumbing near a window is running the vent. Since a toilet can be wet vented, it isn't as big a problem as a sink.
    Quote Originally Posted by trinitony View Post
    I'm now thinking about moving the right wall over 1 foot so that I could have a bigger shower and more floor space with the 6' tub. The MB closet next to the bathroom is (I think) 12 by 8, and really doesn't have to be that large. What u guys think? Moving the wall over will only take a couple hours, so no problem there.
    Extend the tub platform past the window, and make the area from it to the corner the shower stall. Put the door in the center and the toilet next to it. That eliminates the "pinch point" between the shower corner and the tub platform to get to the toilet. The door only has to be 2'-0" clear, because it is not the primary entry, and that should leave you enough room to install a "knee wall" next to the toilet if she does not like to see it when entering the room, since the toilet only needs 30" between the walls.
    hj - sounds like u been talking with my wife. She said the same thing (minus the 30", she say 36" or nothing since she has to clean behind it and to think about resale for some folks), of course when she's talking she's not considering the work involved..lol. The 'pinch point' was a concern and that's why we decided to go out a foot more to the right. Only thing though is that I'm trying to visualize the knee wall. I'll draw a rough diagram of what I think you've said and post it.
    Default Final...
    This is final - it will my third time moving the entrance on the right to my master closet. After visiting showrooms this past weekend, we saw an 8' vanity (3+3+ 2' makeup station) which wifey must have.
    What you guys think?
    If the pocket doors fit in behind the shower, my preference is to build the wall out some to support the tile better than the shallow supports they ususally come with. Also, for the pocket door hardware, check out www.johnsonhardware.com. I was very impressed with their line of hardware. I ended up with a two channel trolly for a heavier door than I had need of, and it is quiet, and moves with barely a push from one end of the track to the other. They have various systems for doors weighing up to (I think) 300#), so they're all overkill for any typical door you might have in a home. I think mine was rated for 150#. Their thin stud replacements are wood wrapped in a metal U-channel to make them stiffer (and straighter!) than the typical stuff you see. I didn't use them, though, and built a normal 2x4 wall for the pocket at the head end of my tub/shower. This gave me room for the plumbing and the flexural strength I felt I needed for the tile.
  1. DWV Layout Problems
    By grymes56 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2010, 10:36 AM
  2. bathroom layout - opinions?
    By nukeman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2010, 05:27 AM
  3. new basement bathroom layout
    By pumsaw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2009, 06:06 AM
  4. Bathroom layout
    By alaskanfam in forum Remodel Forum & Blog
    Last Post: 11-14-2008, 08:15 PM
  5. Bathroom Plumbing Layout
    By Blaze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2006, 07:28 PM
