haha I have never seen, or heard of, Spartan machines but I just googled them and they do look pretty much identical.
Sorry to take so long getting back to you on these questions and statements you posted
# 12.
I only tell it like it is I would not try to sell something I did not have complete faith in as I stand behind the machines, the same as Trojan Worldwide does with the best service plan in the trades
#14
Apples and Oranges the Rigid k400 and Trojan pony are (2) different machines to compare it to the Trojan "Colt" which sells for $999.00 dollars U.S. Add the style and kind of cable you want.
# 15
The Trojan main sewer equipment is patterned after spartan by someone who had many years experience selling Spartan, but the components are all made and assembled in the U.S.A. All parts are 100 percent interchangeable with Spartans.
# 18
The Trojan pony runs either 5/8"x82' or .55''x110' feet of cable to run 3",4",or 6" main sewer line it will also accept with adapters the colt drums running 1/2''x75' for 2'',3'', 4'' sewers, 13/32'' x 75 cables for 1 1/2'',2'',& 3'' sewers or 5/16'' x 35 ft 1/4'' x 35 for small drains and is what i consider the best and most versatile machine on the market.
#18 a
You can also add second or 3rd. main line cables by changing out the drums to run over 246' of main sewer
MACPLUMB 777
E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
I almost missed
#10
Trojan makes the worlds finest quality oil tempered, heat treated, music wire cables and is the first to start offering stainless steel cables over 2 years ago and now has stainless steel closet augers,
MACPLUMB 777
Hey Jerry I heard that their battery powered Pony and Stallion have all kinds of torque over the AC powered units..
Yes they do if you hook up a 1065 to a STALLION battery model with the 1065 running it will stop the 1065 and make it run backwards,
and the battery powered COLT can run a week snaking drains on one charge !
MACPLUMB 777
Trojan battery powered machines are missing something that you cannot run any other machine without
extension cords !
So when you are up to your ankles in sewer water, there is no grounded plug around,
or you just want to save time setting up and reloading your equipment
Trojan stallion or colt is the way to go !
MACPLUMB 777
I bought my PowerSnake in 1975 for about $1,500 with 3 drums and cables. I just replaced its frame because the motor mount finally rusted off, and I have only replaced about 5 cables, so my amortization costs are very low, particularly since I charge a fee every time I use it. Other companies now have their own versions which look just like mine.
Yes professional plumbers that do drain cleaning for a living and not as a sideline when
nothing else is happening run approx 5 to 10 drains a day and the best are lucky to get a
year or so out of a main line cable before it becomes too soft or worn out !
I am sad to say I do not see any one using a power snake that much when there are better
designed drain cleaning machines with power cable feeds etc. That Williams does not
have and by the way I have their current catalog in front of me
I believe in knowing not only the products I sell but also what others are selling also !
MACPLUMB 777
It is fairly easy to do that many calls a day when you are working at a drain cleaning
service company only, with 24 hour a day 7 days a week on call service times !
As for example Roto Rooter was back in the old days of the 70's and before
and if you are a true drain professional you know how to take care of your machines
as while as your cables after all they are your bread and butter !
MACPLUMB 777
I do not abuse my cables. But I do not consider sewer and drain cleaning my "bread and butter". If all I did was sewers and drains, then I might do 10 a day, but then I would not do the other things which really pay my bills.
