Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
Thread: The worlds best sewer tools and equipment !
  1. #31
    Plumber AssTyme's Avatar
    May 2010
    Wisconsin
    I do not abuse my cables. But I do not consider sewer and drain cleaning my "bread and butter". If all I did was sewers and drains, then I might do 10 a day, but then I would not do the other things which really pay my bills.
    I think 10 drain calls a day would pay most anybodies bills ???
  2. #32
    Not when the other calls are more profitable. I am a plumber who does drain cleaning, NOT a drain cleaner who does plumbing. And they have to be very minor drain jobs to do 10 in a day. The guys doing 10 a day are usually charging $59.99, or less, a drain. My MINIMUM is twice that and the one I did this morning ran $650.00.
  3. #33
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    I used to charge twice that and still managed to do 10 or more drain calls a day and yes some of them were easy but again some of them were more time consuming and i only got four or
    five calls done those days,
    i have also spent two or more days working on the same drain problem which evolved
    digging and either repair or replacing the complete sewer line, for example one time
    280' x 6" clay sewer main for a 400 unit apartment complex.
    And yes i am also a MASTER PLUMBER who does drains but I also know and respect the
    man and women who only do drain work for a living !
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
  4. #34
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    I am curious if your company has a urinal auger like the one General Wire makes? It sure would be nice if some company would make one so that it is attached to a leader like a Marco toilet auger and would have a removable head so that essentially the cables could be hooked together so that it could go further down the line once the cable has cleared the trap.
    I am also curious about the idea of joining say, 10 ft lengths of cables together instead of a 100 ft. You could make the cable as long as you wanted within reason. If you kink a section you would only have to replace a section. I would prefer the snap lock. The one thing I don't like about a Spartan is they use roll pins to join cables and heads. I am not a fan of Ridgid at all, they use a quarter turn screw to join cables and heads. They are not a very good machine at all. This is the choice of the day shift plumbing shop at ASU. You should see all the machines setting around with tags on them in an un operable condition. It does not help that there are 15 guys that don't care how they are taken care of either. On the night shift I finally got my boss to buy a Spartan 100, 1065 and a 2001.
  5. #35
    ANY cable connection is a potential failure point, which is why I NEVER even consider a sectional cable. Besides the need to have an "elephant trunk" sticking out behind it to control the cable. I have had my current cables for over 10 years, proper use will usually prevent any damage to them. My PowerSnake also uses roll pins, but they may be the safest way to connect cables and heads together. Bolts and "snap pins" can self disengage, or break, under the right conditions.
  6. #36
    Aug 2007
    Lightbulb The worlds best cameras for sewer and drain work
    Trojan_logo
    ColtPonyStallionBattery Operated MachinesCablesJetter HoseJet MachinesCamera Systems
    Home
    Contact Us
    Catalog
    TROJAN CAMERA SYSTEMS
    Mini Camera
    Mini Camera System
    1-1/2" - 3" Lines
    7/8" Camera Head
    7" LCD w/DVR
    Fiberglass Push Rod and Stainless Steel Reel
    Remote Control for Monitor
    Records to any USB Flash Drive or Laptop
    Optional: Built in 512 Hz Transmitter and Microphone for Recording
    Model# C65-DVR - 65' of Push Rod
    Model# C98-DVR - 98' of Push Rod
    Model# C130-DVR - 130' of Push Rod
    Trojan Color Camera System
    Camera System
    Model# C190-DVR
    3"- 8" Lines
    1-1/2" Self Leveling Camera Head
    190" of 3/8" Push Rod with Stainless Steel Reel
    10" LCD w/ DVR and Built in Microphone for Voice Recording
    Color Camera System DVR
    Camera System
    Model# C380-DVR
    3"- 10" Lines
    Foot Counter
    300' of 1/2" Push Rod
    10" LCD w/ DVR with Built in Microphone for Voice Recording
    Borescope
    Video Borescope
    Model# VBS36
    3' Flexible Shaft with Color Camera Head
    White LED Lights with Brightness Control
    Records to any SD Card (up to 32GB) or USB Flash Drive
    locator sonde
    Locator and Sonde
    Model# RD - Digital Locator - 512 Hz
    Model# SD - Sonde - Optional Attachment to connect on end of Push Rod in Place of Camera Head
    Model# RDLS - Digital Locator and Sonde
    Sales Policy I Terms and Conditions I Privacy Policy
    This site is designed and maintained by Trojan Worldwide, Inc.
    Copyright 2009. All rights reserved.
    Revised: August 14, 2010
    MACPLUMB 777
  7. #37
    Semi retired master plumber freeflow's Avatar
    Aug 2009
    alabama
    Quote Originally Posted by MACPLUMB 777 View Post
    I have taken a 100 machine up on thousands of roofs even two story ones when needed !
    I could break down a 300 machine carry on roof put back together and power snake a
    main line though roof vent and take back to truck in a 1 hr to 1 1/2 hrs. All day long
    the 1065 you run from the ground up over the top rung of the ladder either with one or two men !
    I have run millions of drains all over so. Calif. And the northwest pacific for more then
    30 years !
    That was when we were young and bold , now we old and our nuts and backs are cold , thinking about taking a my tanna m661 in one piece(after 45 yo I wised up and took it apart) and up on a roof makes me sweat in my sleep
  8. #38
    Aug 2007
    Yes me too these days !
    MACPLUMB 777
  9. #39
    Homeowner
    Jan 2010
    Alabama
    So shoot me some prices on a 100' color camera that can record to my laptop and I can use my laptop as the monitor. I would also need a locator and the camera would need to have a sonde.
    I might even could come get it and see it work first. A business trip to Houston sounds good to me.
  10. #40
    quote; I have run millions of drains all over so. Calif. And the northwest pacific for more then
    30 years !
    Figuring a 200 day work year, just doing one million works out to about 170 drains a day. You must be exhausted.
  11. #41
    Aug 2007
    So who only works 200 days a year, ? ?
    Try 350 or more days a year was what i was working most of my life !
    MACPLUMB 777
  12. #42
    Aug 2007
    Trojan_logo
    800-392-4902
    ColtPonyStallionBattery Operated MachinesCablesJetter HoseJet Machines Camera Systems
    Home
    Contact Us
    Catalog
    Mini Camera
    Mini Color Camera System
    1-1/2" - 4" Lines
    7/8" Camera Head
    7" or 10" LCD w/DVR
    Records to any USB Flash Drive (2GB Included)
    Camera System Only Camera System
    w/512 Hz Transmitter Camera System w/512 Hz Transmitter
    10" LCD and Recording Microphone
    65' of Push Rod Model# C65-DVR Model# C65-DVRSD X
    98' of Push Rod Model# C98-DVR Model# C98-DVRSD X
    130' of Push Rod Model# C130-DVR Model# C130-DVRSD Model# C130-512
    Self-Leveling Color Camera System
    Model# C190-DVR
    4"- 8" Lines
    Includes 3 Skids: 3" - 4" - 6"
    Model# C380-DVR
    4"- 10" Lines
    Foot Counter
    380' of 1/2" Push Rod
    locator sonde
    Locator and Transmitter
    Model# RD 512 Hz Digital Locator
    Model# SD 512 Hz Transmitter - Sends signal up to 15' in PVC and 10' in Cast Iron
    Model# RDLS 512 Hz Digital Locator and Transmitter Package
    Borescope
    Video Borescope
    Model# VBS36
    Includes 3 Different Attachments
    800-392-4902
    MACPLUMB 777
  13. #43
    DIY Junior Member PipeInspection's Avatar
    Apr 2012
    New Jersey
    New to the site, but thought I'd drop a post to say hello.
    Looks like we have a fellow Pipe Camera provider here.
    Hope all is wells.
    Paul
  1. Suggestions as to what this equipment is ???
    By dabiz7 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-19-2010, 12:25 PM
  2. damaging new equipment???
    By fast pasquale in forum Computers and Stuff
    Last Post: 02-25-2007, 03:09 PM
  3. worlds oldest flapper....
    By Racer814 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-06-2007, 07:15 PM
  4. Worlds biggest toilet
    By petergunn in forum Toilet Forum discussions
    Last Post: 01-07-2007, 08:23 AM
