Results 1 to 5 of 5
Thread: spalling concrete
    DIY Member tregg's Avatar
    Dec 2009
    Iowa
    Default spalling concrete
    What are the remedys for spalling concrete? It's in my basement but not on a load bearing wall. It is next to the stairs going up and is on the edge of the attached garage so there is earth on the other side of it.
    There are various concrete products designed to top your slab. Will this ever be finished with something on it? Maybe tile, carpet, etc.? Then, it may not matter.
    Dec 2009
    Iowa
    Thanks Jim!
    Plumber jimbo's Avatar
    jad....I think he is talking about a wall surface, not a floor slab. He mentions earth on the other side, and a contiuously wet wall which was not waterproofed on the outside can fall victum to spalling.
    Hydrostatic pressure may make any topping fail. You may want to call the manufactuer of the product. Two companies that make stuff for this are Ardex and Custom Building Products. There are others. Check their websites, read the spec sheets, and then call and talk to a tech to find the best product. Some of them require a primer first (a bonding agent), and that usually requires the area to be dry. Depending on the weather and ground conditions, you may only have a narrow window of opportunity to do this.
  1. Can I concrete around ABS?
    By manintrees in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2009, 09:21 AM
  2. Concrete Spalling
    By ttw4454 in forum Remodel Forum & Blog
    Last Post: 06-19-2007, 11:41 PM
  3. Concrete to PVC
    By tbondiek in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2006, 07:54 AM
  4. To concrete or to not concrete!
    By bradlf in forum Shower & bathtub Forum & Blog
    Last Post: 11-07-2005, 03:49 PM
  5. Anyone know anything about concrete?
    By smhowell in forum Remodel Forum & Blog
    Last Post: 09-03-2005, 11:36 PM
