Results 1 to 12 of 12
Thread: Franklin 3 HP Deluxe Control Box parts
    DIY Junior Member andybull's Avatar
    Jul 2010
    SC
    Default Franklin 3 HP Deluxe Control Box parts
    Can someone please tell me where I can buy parts for model # 282 302 8310 at a good price?
    Start Overload 275 411 118
    Run Overload 275 411 115
    Contactor 155 325 102
    Relay - 230 V* 155 031 102, or103
    TIA,
    Andy
    Jul 2010
    SC
    I need the relay, I would however like to know the prices for the rest. The cheapest deluxe box I've found is around $220.00.
    BTW, why install a Deluxe box over a standard? This is the second relay to go out on this well. The well was used to construct the house, it was shut off and when I turned it on the other day it ran, pressurized the tank, stopped and would not re start.
    DIY Junior Member Ichabod's Avatar
    Jan 2010
    Statesboro, GA
    When I went shopping for parts versus new box, local or online purchase, I found that a new box purchased locally was less expensive.
    Ichabod
    Moderator valveman's Avatar
    Mar 2006
    The relay in the deluxe box takes all the amperage off the pressure switch. If you are burning relays or pressure switches, you need to do something to reduce or eliminate the cycling.
    DIY Member Rutherfordman's Avatar
    Mar 2009
    North Carolina
    Some of the folks on the board may be able to supply you with parts. I will let them chime in if they have any. I have learned to test and replace the parts in mine for much less than a new box costs. Lightning is my enemy and it usually takes out the relay and maybe a reset button. I can have the breaker off and lightning will cook the relay still. All I can figure is it comes in on the ground wire so now I have a way to disconnect it. Below are some online places which have some parts if you cannot find elsewhere.
    http://store.thepumpwarehouse.com/pr...rts/Categories
    http://www.wilsonelectric.com/franklin.htm
    http://www.sealdistributors.com/capa...anklin.htmhttp
    Jul 2010
    SC
    Rutherfordman:
    Can you please check the link for seal distributors?
    Mar 2006
    Andybull, try posting on this thread again. I don't see any problem.
    Mar 2006
    Well I guess there was a problem. Try again.
    Jul 2010
    SC
    Thanks for the replies. I purchased a box on **** which I will install, I would like to keep the old box as a spare so please let me know where to get the best prices for the guts.
    Andy
    Jul 2010
    SC
    Grainger does not sell the parts for the box.
    Mar 2009
    North Carolina
    Definitely keep the old box and rebuild it. You will be glad you did if the new one goes out. This gives you time to hunt down the parts and not have to buy another new box. If the Seal Distributors link does not work just go to their main page. As I stated the Relay is usually what goes in mine and it runs around $45.00 or so. I had a great place to get parts called Roanoke Armature but they quit selling them recently. I am always looking for new places to find parts so if you run across anything let me know. Franklin gives you great testing info on the inside of the box cover. I am no electrician so if I can figure it out anyone can.
  1. Franklin Box Parts
    By Rutherfordman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-26-2010, 02:59 PM
  2. Parts for Franklin Control Boxes
    Last Post: 05-18-2009, 05:08 AM
  3. Replacing Control Box, Franklin
    By Leaky Boot in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-09-2008, 07:16 AM
  4. Franklin pump controller info?
    By low_pressure in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-17-2008, 08:21 AM
  5. Franklin motor parts
    By FLATFLAME in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-02-2007, 06:40 AM
