Results 1 to 12 of 12
Thread: Which Cast Iron Flange Replacement is best
    DIY Junior Member tomtbone's Avatar
    Feb 2010
    tomtbone in Boston
    Default Which Cast Iron Flange Replacement is best
    Today I successfully removed the old cast iron toilet flange and am left with a 4" cast iron pipe. The top of the pipe will be about 1.25" below the level of the finished floor. I am looking at a couple of PVC/ABS replacement flange from Oatey and Sioux Chief. Which one would you guys reccomend?
    Oatey Compression joint with screws to tighten compression
    Oatey Twist 'n' Set
    Sioux Chief Gasketed Closet Flange
    Sioux Chief Push-Tite Flange
    In the Trades Wally Hays's Avatar
    Nov 2009
    They are all about the same but I like the ones with a stainless steel ring.
    Perception is 3/4 of reality
    Feb 2010
    tomtbone in Boston
    Also, PVC or abs
    ABS vs PVC is irrelevant when attaching to CI, so pick the one you can get easily, or is less expensive. I'd definately go for one with the (stronger) SS ring, though. Won't rust, or deflect or break as easily as an all plastic one.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    THIS IS WHAT YOU NEED THOSE CHEAP PLASTIC FLANGES ARE JUST THAT CHEAP !
    THEY ARE MADE AS REPLACEMENT FOR BAD PLASTIC FLANGES !
    YOU NEED TO GO TO FRANK PATTERN & MANUFACTURING WEB SITE THEY HAVE ONE THAT IS 4" X 4"
    TO BRING YOUR REPLACEMENT UP ABOVE THE FINISHED FLOOR LEVEL WHERE IT NEEDS TO BE
    http://www.instantset.com/closet_rings.htm
    Home
    Announcements
    Product Catalog
    Closet Rings
    Cast Iron
    Model Numbers
    Size
    Regular
    3"x2"
    30
    4"x2"
    40
    4"x2"
    40TC
    (w/test cap)
    Instant SetŪ - Closet Ring 4"x4"
    Model Numbers
    Size
    Regular
    Deep
    4"x4"
    44
    Instant SetŪ - Closet Ring 4"x6"
    Model Numbers
    Size
    Regular
    Deep
    4"x6"
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Feb 2010
    tomtbone in Boston
    So do those flanges fasten to the outside of the pipe then? I'm not quite getting how they work. Also, for the 2" deep size, how much pipe does there need to be to grab onto?
    Feb 2010
    tomtbone in Boston
    Any compression flange will ONLY seal if you can get the pipe smooth enough. I ONLY install cast iron flanges on cast iron pipes.
    Feb 2010
    tomtbone in Boston
    I understand that yes. What do you do though if the cast iron pipe is more than an inch below the finished floor level? Are those blue cast iron compression flanges adjustable?
    I also saw at Lowe's today that Oakey is making a cast Iron Twist and seal flange
    Aug 2007
    The blue cast iron instant set tightens on the outside of the pipe by tighting the 3 7/16 bolts
    around the flange, !
    That is why you get one that is 4" deep it sets down below the floor and extends up to
    above flooring to make the correct fit !
    MACPLUMB 777
    Aug 2007
    If i was doing it i would take both 4x2 and 4x4 to dry fit and make sure it tightens
    correctly and will work properly ! !
    Then return the one i don"t use !
    MACPLUMB 777
    I think what HJ was alluding to was that he only installs a new leaded ci flange on a ci pipe...they come with different depth throats to accommodate the height of the ci riser. This is the longest lasting, strongest connection, least likely to leak of all of the choices.
  1. Can you use Twist-N-SetŪ Cast Iron Replacement Closet Flange
    By k9 in forum Toilet Forum discussions
    Last Post: 01-17-2010, 04:37 AM
  2. Cast iron pipe replacement
    By davisc in forum Plumbing Forum Discussion & Blog
    Last Post: 05-30-2007, 02:21 PM
  3. Cast Iron VS. ABS - replacement
    By Boink in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2007, 10:39 AM
  4. Cast iron flange or flange extension (?) below tile floor
    By gardengirl in forum Toilet Forum discussions
    Last Post: 12-31-2004, 09:54 AM
  5. Caulking for cast Iron Flange Replacement?
    By jdkimes in forum Toilet Forum discussions
    Last Post: 11-29-2004, 09:59 AM
