Results 1 to 2 of 2
Thread: Test ball location
    DIY Junior Member blitziger's Avatar
    Jun 2010
    Portland, OR
    Default Test ball location
    I've just finished the replacement of some under slab ABS rough plumbing, placed a test ball in the main drain at the test tee, and all seemed to be sealed with 10' of head. I bought the ball type tester with the chain because it was considerably cheaper than the balloon type that threads into the tee. I'm only going to use it once after all.
    Two questions:
    1. Where does the test ball go for the test, before or after the test tee? I placed it after, filled the system and then stuck a old piece of hose down the vent and siphoned the water out to a sewer clean out in the yard. All very unsanitary. Still had a little water left when I opened the tee cap, but worked out well in the end.
    2. One of the ABS clean threaded cleanout plugs leaked even after I screwed it in all the way. What do you use to seal the threads so the cap can be removable?
    1. You put the plug on the upstream side of the test tee with the chain and loop outside the tee so it cannot get washed down the pipe when it deflates, whether intentionally or by accident.
    2. After the test, you deflate the ball and the water flows past it down the drain.
    3. Sometimes you CANNOT make the plug watertight. I either put a rubber test cap OVER the plug and tighten it to the tee's opening, or divert the leaking water away from the pipes so the inspector can tell that the pipe itself is not causeing the wetness.
  1. Test ball / balloons?
    By exeunt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2010, 02:41 PM
  2. air test vs water test
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2009, 11:40 PM
  3. Ball valve
    By novice-man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2009, 09:28 PM
  4. DWV cleanout plugs weeping & test plug blowout during water test
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2006, 11:38 PM
  5. Test Ball Woes...
    By Spaceman Spiff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2006, 11:16 AM
