Thread: What to put on the window ledge??
    DIY Senior Member ingeborgdot's Avatar
    Mar 2008
    Kansas
    Default What to put on the window ledge??
    I got a new window a while back. I am going to put sheetrock around the interior. The question I have about this is what do I put for the base or ledge of the window. Some carpenter told me to put 1/2 or 3/4 " plywood instead of sheetrock and texture it like the rest with corner bead and such. I am not sure if that is right or would plain old sheetrock be the right way to go? Thanks.
    I prefer fir for the window ledge.
    But you don't want drywall, any moisture there and it's not going to hold up well.
    A table saw is a must for cutting the wood to the right width.
    Jul 2007
    USA
    I use oak varnished with a quality exterior varnish to resist moistire and UV on the inside.
    Some things you will need to think about before you buy the wood are:
    1) the depth of the wood. You do not want to come up too short but can get away with an overhang of a few inches.
    2) the width of the wood. Too thick and there is a drop before the window frame.
    I use screws to attach the very ends of the sills to the lower header. The drywall on the sides of the opening then covers the screws.
    Mar 2008
    Kansas
    I am going with a contemporary modern look and stained wood just won't work in this situation. I will be mudding the sheetrock and maybe use an orange peel texture. I have some 1/2" pine or fir not sure which that I could use to match the thickness of the sheetrock.
  1. Kitchen Window Opinion??
    By wallygater in forum Remodel Forum & Blog
    Last Post: 03-08-2010, 11:04 AM
  2. What sealant for window well?
    By Macman in forum Remodel Forum & Blog
    Last Post: 10-20-2009, 07:00 AM
  3. window in shower waterproofing
    By daddio in forum Remodel Forum & Blog
    Last Post: 09-08-2009, 08:16 PM
  4. window replacement
    By rburt5 in forum Remodel Forum & Blog
    Last Post: 06-07-2008, 09:56 PM
  5. bedroom window
    By johnapril in forum Remodel Forum & Blog
    Last Post: 05-09-2006, 07:22 PM
