Results 1 to 3 of 3
Thread: Outlet Spacing
    DIY Junior Member Yankee1423's Avatar
    Jul 2010
    Iowa
    Default Outlet Spacing
    I'm drawing up my electric plan for a basement finish and came ran into a spot where I may have electrical outlet overkill. This all goes back to the rule requiring outlets on any wall 2' or more. As you can see in the diagram, I have a closet in the bedroom where the walls are all right around 25" or so. Am I going to need outlets on each wall marked 25"? That seems to be a little much to me.
    Jun 2007
    North Carolina
    What I see is one wall that is 50.5 inches from the door to the closet. This area would require one receptacle.
    From the closet to the door is one wall where a receptacle would be required within six feet of the door and 12 feet on center thereafter. This would be the minimum but if my heart desired I could put one in every stud bay,
    What I don’t see is a 25 inch or an 8 inch wall anywhere in your drawing.
    DIY Junior Member BhamRuss's Avatar
    Jul 2010
    Birmingham, Michigan
    You need to review the wording of the applicable code. The codes I'm familiar with allow the spacing to turn corners. (Walls aren't defined as corner to corner, but rather by interruptions such as doorways, fireplaces, etc.)
  1. Replies: 9
    Last Post: 12-11-2012, 12:01 PM
  2. Black pipe/dryer vent spacing?
    By mastas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2009, 05:55 AM
  3. Spacing Multiple Points
    By mrjaybov in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-13-2009, 05:43 AM
  4. toilet spacing
    By thezster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2009, 05:18 PM
  5. min spacing hot cold copper lines...
    By chris fox in forum Remodel Forum & Blog
    Last Post: 01-10-2008, 08:38 AM
