Results 1 to 12 of 12
Thread: Ooodles of Iron
    DIY Junior Member RobPaula's Avatar
    Jul 2010
    Canada
    Default Ooodles of Iron
    My water test is as follows...
    pH 8
    Sodium 79.96 PPM
    Potassium 4.23 PPM
    Calcium 69.23 PPM
    Magnesium ((Perhaps Manganese, don't remember.) 18.51 PPM
    Total Harness 249.09 PPM
    Iron 13.01 PPM
    Total Alkalinity 382.8 PPM
    Carbonate 0 PPM
    BiCarbonate 467.1 PPM
    Hydroxide 0 PPM
    Chloride 14.7 PPM
    Fluoride .2 PPM
    Nitrite 0 PPM
    Nitrate 0 PPM
    Sulfate 26.7 PPM
    Total Disolved Solids 443.29 PPM
    13.01 PPM iron, that's not a mistype. Last week after a heavy shocking (We have to shock every 3-6 months) it was 3 PPM, 6 days later it's now 3.4 PPM. The 13.01 was bad, pre-shocked water. Shocking the well only lasts about 6 weeks before our filter can't handle the volume and we start getting staining again. Our local well guy wants to put in a greenbed system with potasium permanganate paired with a softener, but from everything I've read, I'm not entirely convinced this will be sufficient with iron and magnesium levels this high.
    Any info would be greatly appreciated.
    Rob
    There are better ways to deal with iron such as air/chlorine injection followed by a backwashing filox or carbon filter, but you manganese is also very high. The high manganese most likely will have to be delt with along with the iron and may determine how you will filter out the iron.
    Unfortunately I don't know how to deal with high manganese, but maybe someone else can hep?
    -rick
    Jul 2010
    Canada
    I double checked last and it's magnesium, not manganese. I believe the chlorine injection model "should" take the magnesium out as well. Is that correct?
    Magnesium and calcium make up hardness. Manganese is like iron, it must be oxidized and then filtered, the same as for iron.
    Jul 2010
    Canada
    Thanks for that Gary. OK. So would I correct in assuming a system employing a chlorine pre-treatment would be the most effective solution for high levels of iron and sulfates, but would still require a softener to deal with the hardness? I'm aiming for something that can remove 30ppm+ so that there is some room to move if my water takes a turn for the worse.
    DIY Member royerm's Avatar
    Jul 2010
    Quebec, Canada
    RobPaula.......I have a similar situation at 4.8 PPm of Iron but I'm interested on your "shocking" process...
    What do you use????
    and How Much?????
    My challenge is that that my 150' deep well is constantly overflowing and wondering how efficient pouring something inside will be or will I be wasting it all????
    Thx
    Jul 2010
    Canada
    Quote Originally Posted by royerm View Post
    What do you use????
    and How Much?????
    Thx
    Hmmm, well, we have a huge well with a lot of water and very fast refresh rate. Our well is a 24" bored well and 90 feet deep with about 70 feet of water. From what I understand we're supposed to take water out of the well, shock it, and put it back in to the well to force the bleached water in to the aquifer. Well, what I would need to do it properly is about the equivelent of two water trucks of bleached water and that is not feasible.
    This is the process I follow.
    1. First bypass the whole-house filter if you have one.
    2. What we do, because of the size of our well, is we use an entire 20 liter jug of 12% sodium hypochlorate. That is the equivelent of 50 liters of regular household bleach. Pour it in to the well. Generally, this can be purchased at farm supply stores and is much cheaper than household bleach.
    3. We then cycle the waterout through the hose and back in to the well for a couple hours until the water and bleach are well mixed and we can smell the bleach in the hose water.
    4. Once this is done, we then run the water in to the house, up to all the faucet, fixtures and appliances until the bleach smell is evident.
    5. Then we run the hot water until it runs cold to ensure all the water in the hot water tank has been run out.
    6. Then we go away and leave it sit for at least a couple days.
    7. After that we come home and drain the well. Takes about 10 hours for me and never truely runs out. Wait for the water level to refresh, about 40 minutes for me.
    8. Un-bypass the filter and drain the bleached water from the household lines.
    9. Run the hot water until it runs cold.
    Because of the size of our well, this is the process which was recommended to us by some local guys as a not ideal solution, but workable. The day after completing the most recent shocking, if I can believe the guy that tested out water and I don't consider him reliable, he says our iron was sitting at 3ppm. One week later, it was at 3.4ppm. That was after sitting with the bleach for 4 days. It's at a level our current filter can handle, but it only lasts about 6 weeks before the filter can't handle it and we start to get staining again.
    Jul 2010
    Quebec, Canada
    RobPaula..... First I would like to Thank you for taking the time to answer with such details.
    I'm definitely getting the heck of what and how to do it.
    I do have a faucet that bypass everything...
    Thx a million..
    Quote Originally Posted by RobPaula View Post
    Sulfates must be ion exchanged with anion resin but, you don't have a problem with sulfates. Here you are allowed up to 250 ppm and they are not a health concern.
    I have used a special resin (SST) in a softener with a special distributor tube (Turbulator, no gravel) )on up to 13 ppm of iron and having the person use Iron Out periodically to clean the resin.
    Chlorine in an inline pellet chlorination system would do more than oxidize the iron, it kills all bacteria etc. also. Then a softener for the hardness sized for the house peak demand flow rate.
    Jul 2010
    Canada
    Thanks Gary. I was confusing sulfates with SRB. It's 250ppm here as well. Chlorine it is.
    DIY Junior Member emoque's Avatar
    Jul 2010
    Asheville, NC
    We have 1.57 mg/l in our water...is that high? I see that most here have been in ppm. Thanks.
    AAW jimtum's Avatar
    Aug 2010
    Decatur Tx
    I would recommend air injection over chlorine since it is less problematic and not a harsh chemical but it does disinfect the lines. My thought would be an Iron breaker and then a water softener and you would have your problem solved. The iron breaker will bring down your iron to a point that your water softener would be able to pick up any left and soften your water also. for the iron filter I would use a 2 cu ft filter and a 1.5 cu ft softener.
  1. Too much iron
    By hampton roads Virginia in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-05-2010, 02:34 PM
  2. iron problems
    By rihorton in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-05-2010, 06:19 PM
  3. Iron Or What???
    By Spyder in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-15-2009, 11:33 AM
  4. cast iron fitting installed in cast iron soil pipe
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2009, 06:20 AM
  5. abs to cast iron
    By latexia707 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2007, 01:08 PM
