Results 1 to 8 of 8
Thread: Cutting And Then Extending Well Casing
    DIY Junior Member Regis Tration's Avatar
    Jul 2010
    Massachusetts
    Default Cutting And Then Extending Well Casing
    I have a well in a very remote location close to the ocean, where it is exposed to salt air. The portion of the well casing that is above the soil is severely corroded.
    I would like to replace the corroded casing.
    I had in mind to dig out the soil surrounding the casing a few inches deep, cut away or break away the portion of the casing that is corroded, push a sleeve down over the part that is not corroded, and then insert a new piece of casing into the other end of the sleeve.
    It is very unlikely that I could get a welder to come to the well, so I am looking for a solution that does not involve welding.
    Can anyone recommend a good method and products please?
    In the Trades Wally Hays's Avatar
    Nov 2009
    It's not approved but you could dig down a bit and cut it off and then extend it using a Fernco coupling and then go to PVC which will not corrode.
    Perception is 3/4 of reality
    Jan 2008
    Virginia Beach, VA
    Fernco couplings are not an approved repair on any well anywhere!
    Your DIY remedy sounded best. Cut the casing off at a point where the casing is good. Then obtain a belled end of PVC the size of your steel casing, see that it will fit tight over the steel casing and if it will apply plenty of PVC Cement and push it over the cut off casing. NOTE: if the PVC is a little to small you can heat it over an car exaust or place the end in hot water until it's soft, then you can drive it over the casing, then let it cool befor removing it and applying PVC Cement. This is an approved repair in most states. . . however keep in mind that most states require this repair to be done by a licensed well driller. From here on you're on your own.
    Good Luck
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Nov 2009
    I'll back Porky.
    Jul 2010
    Massachusetts
    Thank you both.
    Dec 2009
    northfork, california
    BP is doing something like that right now a little bit deeper underwater.
    Quote Originally Posted by ballvalve View Post
    Pretty witty!
    Cut it off, then either thread the end of the pipe and couple on to it, or use a water line compression coupling, such as Dresser to extend it.
  1. Extending an Existing Well
    By lzenglish in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-08-2009, 02:13 PM
  2. Extending The Well Casing
    By tsingerjr in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-26-2009, 06:08 PM
  3. Extending Well casing
    By estone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-30-2008, 05:08 PM
  4. Cutting and extending ABS
    By hans_idle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-24-2008, 06:12 PM
  5. Extending ungrounded circuit
    By muzz in forum Electrical Forum discussion & Blog
    Last Post: 11-18-2007, 09:46 AM
