turkinpa
Today I had installed in my home a Bryant 355 CAV furnace, 187BNA 036-A Air handler, and an Evolution control system.
My question is when I change the fan speed at the thermostat, shouldn't at some point the fan motor run faster or slower depending on the setting? No matter where it is set, (low, medium, high, or auto) the fan motor remains constant. And there is no change in the amount of air being pushed out of the duct work. Is it possible the wiring was done wrong? The house won't cool down below 77 deg. The contractor only says "you gotta give the equipment 48 to 72 hrs. to remove the humidity."
I'm confused and HOT!
Any help would be greatly appreciated.
