Gregory Moeser
I am trying to replace an effluent pump. The original pump was a Goulds. For unknown reasons after four years the pump a PS41P1F has quit. I have to pump uphill to a septic bed. The vertical lift is 26 feet. The original set up was using a 1.5 inch discharge at the pump reduced to 1 inch inner diameter black plastic pipe and also involving one 90 degree elbow. I have purchased a Berkley EC240120TB which has a maximum head of 33 feet. at 26 feet head it is rated to produce approximately 25 gallons per minute. Will this pump do the job? Can I eliminate the 90 degree elbow using a straight connector and some braid reinforced plastic pipe at the pump end?
Thanks for any suggestions.
Greg
Greg
