Results 1 to 8 of 8
Thread: PEX stub outs - how do you do yours?
    DIY Junior Member TristanP's Avatar
    Apr 2010
    Delaware
    Default PEX stub outs - how do you do yours?
    This is for the laundry sink on/in a base cabinet in the laundry room move I'm still working on. Would you go with this
    or this?
    I believe I have space for either. PEX is 1/2". Thanks.
    In the Trades Wally Hays's Avatar
    Nov 2009
    That's fine. For a complete idea of all the PEX stub out and hanging options try Souix Chief's web site. If it's for plastic, they make it.
    Perception is 3/4 of reality
    Apr 2010
    Delaware
    Wasn't a yes or no, more of a this or that. :-) Thanks. *off to check Sioux Chief*
    Dec 2007
    There are a multitude of acceptable methods, if there was an aggressive water condition I would go with as much PEX as possible.
    Nov 2009
    Victor, MT
    If it was going in my house I would use the DE 90 and a brass nipple. Brass will hold up better than bent tube with aggressive water and repairs or alterations in the future will be simpler with less things that can go wrong. (No pulling of compression sleeves, for example)
    Nov 2009
    If I had too ( and mind you I wouldn't use pex for a dog house ) I would use bend supports and bring the pex right out through the wall and then you can just whack it off to the right length and use a Sharkbite stop and waste valve. Less fittings = less leaks.
    Network Engineer rmelo99's Avatar
    Jul 2006
    I used the drop ear type that you showed in your second pic. That allowed me to use conventional brass nipples and stops under all of the sinks. I have a home run pex system, and with all the issues with bad brass fittings in the pex world, I wish I hadn't.
    I've not had an issues but those are my one weak spot. I don't anticipate any problems with the tubing. If I did it again I would probably bring the pex out of the wall with those metal stud to stud brackets.
    If I were to do it, I would use the top version, but also place a Talon fastener on the horizontal section to prevent rotation.
  1. Stub-outs
    By Steve E. in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2010, 08:14 PM
  2. pex to copper fixture stub outs
    By remodelbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2008, 11:28 AM
  3. Removing Old Cast Iron Clean-outs
    By Verdeboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-14-2007, 09:36 AM
  4. Height to stub outs....
    By Randyj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2007, 06:30 AM
  5. Stub outs
    By damorej in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-05-2005, 03:00 PM
