Results 1 to 2 of 2
Thread: Getting gas line reinstalled
    DIY Junior Member rafael's Avatar
    Apr 2010
    SF
    Default Getting gas line reinstalled
    Hey Everybody,
    I just learned that the tankless water heater in my home wasn't installed with a properly fitted gas line. The line is one-inch and probably travels about 50-60 feet to the closest gas appliance. In addition to the Noritz N-069, other gas appliances are a 4-burner stove and oven, washer, dryer and furnace. The heater seemed to work just fine, but a few plumbers said the line we have now doesn't deliver enough BTUs to all the appliances.
    The plumbers are recommending I installed a 1-1/4-inch dedicated gas line. I really didn't want to do this, because the gas line is going to run smack dab in front of our house. Does anyone have any suggestions for things we can do to prevent this gas line from looking like an eye sore?
    Also, anything else I should watch out for as I go about doing this job. So far, this water heater has been a nightmare for us. We just want to make things right.
    Thanks a lot.
    Jan 2008
    It would probably be more economical to get rid of the tankless and install a standard tank heater. Unless you need an unlimited supply of hot water, a tankless is not a good choice for most.
  1. Just moved and reinstalled Culligan Mark 100 and Have Some Resin in Backwash
    By jkmason in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-01-2010, 10:32 AM
  2. Old toilet reinstalled after bathroom remodel leaking...
    By Snarlla in forum Toilet Forum discussions
    Last Post: 04-22-2010, 11:36 AM
  3. split line of 2" copper water line from city
    By novice-man in forum Plumbing Forum Discussion & Blog
    Last Post: 08-05-2009, 02:55 PM
  4. Tapping new PVC sewer line into old existing clay line
    By Don Richmond in forum Plumbing Forum Discussion & Blog
    Last Post: 10-20-2008, 08:11 PM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum Discussion & Blog
    Last Post: 10-12-2004, 06:20 AM
