Results 1 to 10 of 10
Thread: Installing a sink tailpiece
    DIY Junior Member bp77's Avatar
    Apr 2007
    New York
    Default Installing a sink tailpiece
    I installed the sink about a year ago, looked under the sink and the tail piece looks like it has a tiny leak where it threads into the drain (the part that attaches to the bottom of the sink). So I took it off and the p-trap, cleaned everything off.
    I applied some oatey pipe compount #31226, grey, and then wrapped 3 times with telfon tape and reinstalled. Is this correct?
    Also why does the tape always bunch up, I put it on the treads clockwise. I assume there is nothing I put on the PVC P-trap treads on the other side of the p-trap.
    [IMG][/IMG]
    Aug 2009
    South*East
    If your going to use both pipe dope and T-tape apply the tape first then the dope. Are you sure it's coming from the tail piece? It may be coming from the connection above it.
    John
    The tape bunches up because there is not enough room inside that connection for three layers of it.
    Dec 2007
    I'll agree many times the leak is coming from the mack washer on the drain above.
    Make sure you check that carefully and if it is post back for a solution.
    Apr 2007
    New York
    It's not the Mack washer. There was some mineral deposits around the tailpiece connection, and it was a bit loose.
    So should I take this apart again and redo it?
    Those are very fine threads , and 3 wraps of tape could be too much. If it is together and not dripping,. let it be!!!!!!!
    Apr 2007
    New York
    Well, it does not appear to be dripping. I don't like the look of the extra white tape, looks sort or homeowener DIYer ; )
    If I decide to redo it, would you use paste or tape? If tape should I fold it in half and wrap once?
    The only pain is I have to disconnect the entire p-trap to get the tailpiece out ; (
    Apr 2007
    New York
    Just don't look. If it isn't leaking, quit beating yourself up. Now..........where's the beer.
    I like dope on those threads. It hides better.
    If the tailpiece is tight, and you just don't like the look of the tape, unpeel the excess which is showing. It is not doing anything anyway.
  1. installing kitchen sink
    By Annabel in forum Plumbing Forum Discussion & Blog
    Last Post: 08-13-2009, 08:53 AM
  2. Installing pedestal sink
    By tnron72750 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-22-2008, 06:00 AM
  3. New Sink: 1-1/2" to 1-1/4" Trap to Tailpiece
    By Madera in forum Plumbing Forum Discussion & Blog
    Last Post: 05-04-2005, 08:48 AM
  4. double sink problem tailpiece drain
    By missing in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2005, 03:47 PM
  5. installing a vessel (sink)
    By cheri in forum Plumbing Forum Discussion & Blog
    Last Post: 12-07-2004, 08:54 PM
