Results 1 to 5 of 5
Thread: Proposed drain and vent for bathroom remodel, UPC
    DIY Member arfeller's Avatar
    Aug 2007
    Port Angeles, WA
    Default Proposed drain and vent for bathroom remodel, UPC
    I've read through a lot of different posts and I think I have came up with the correct venting and drain configuration. I'm not very good at drawing so hopefully it makes sense. My vanity, toilet and tub are all along the same wall that is about 10' feet long.
    The main sewer line comes up directly under the wall behind the toilet. So the main line comes up and vents up through the wall behind the toilet. I think i need a double combination y-1/8 bend for the bottom drain and a san tee for the upper vent split.
    One edit... the sanitary tee for the vent should be turned upside down. Not correct in picture
    Thank you for spending the time to look at my question.
    Rob
    When you turn the vent cross over in the drawing you will be fine.
    Below is an example of two story plumbing
    Aug 2007
    Port Angeles, WA
    Thank you Terry.
    I have been told several times that the sanitary tee is acceptable to use for two drains into a vertical stack. I currently have a double y with two 45's for the drain. Would a sanitary tee be acceptable here?
    A sanitary doube tee would work under the toilet, pretty common in fact.
    Merlin Blue used to plumb his that way.
    As you can see from my drawing, I like to keep the 2" lines tighter to the main stack, and then trap arm over with 1-1/2".
    I use more wyes adn keep everything tighter.
    That cuts up the framing less. The framers loved me and used to ask me why the others plumbers didn't do layout the way I did. The answer, they didn't car how much wood got taken out.
    Aug 2007
    Port Angeles, WA
    I appreciate the reply. Very helpful.
    Thank you!
  1. Drain routing in bathroom remodel
    By austintx in forum Plumbing Forum Discussion & Blog
    Last Post: 10-08-2009, 02:43 PM
  2. Proposed layout for bathroom drain lines
    By pghsebring in forum Plumbing Forum Discussion & Blog
    Last Post: 10-01-2009, 01:22 PM
  3. Bath Remodel / drain and vent design
    By Interlodge in forum Plumbing Forum Discussion & Blog
    Last Post: 07-23-2009, 03:12 PM
  4. Bathroom remodel - lead sink drain
    By Redline in forum Plumbing Forum Discussion & Blog
    Last Post: 10-06-2006, 04:01 AM
  5. Bathroom Remodel - Toilet Drain Lines
    By ptl_10 in forum Remodel Forum & Blog
    Last Post: 08-11-2005, 05:57 AM
