Results 1 to 4 of 4
Thread: Recommendation for toilet in a (sort of) back-to-back configuration
    DIY Member jadziedzic's Avatar
    Aug 2006
    New Hampshire
    Default Recommendation for toilet in a (sort of) back-to-back configuration
    I'm looking to replace the circa 1990 toilets in the second-floor baths of my home; I think the existing units are 1.6 GPF, made by URC (?). The bathrooms are in a sort of back-to-back configuration with a horizontal "W" connection (see drawing). The W fitting runs parallel to the floor, with the discharge end taking a 90 downward to the drain, and the center opening taking a 90 upward to vent through the roof. The wet wall is non load-bearing, with the kitchen ceiling immediately below.
    I've read on this forum that back-to-back toilets using a sanitary wye can interfere with each other, particularly with the newer models with 3-inch flush valves. Is this configuration going to be susceptible to the same sorts of problems? Should I stick with replacement units with 2-inch flush valves to minimize any siphon action on the "other" unit when one toilet is flushed? I've been considering Toto, would need an elongated bowl (compact would be nice but not necessary).
    Re-working the drain connections will be problematic due to the amount of tear-out and re-work necessary. We've never seemed to have any interference issues in the 20 years we've lived in this house ...
    Thanks,
    Tony
    With that fitting, there is no way a toilet would skip across.
    Your choices are open.
    Aug 2006
    New Hampshire
    Great, thanks so much for the quick answer, Terry!
    When the piping is installed properly, there is NO skip across regardless if the toilet you use. If they are installed improperly, there is no way to prevent it no matter which toilet you install.
  1. Back-to-back toilet installation
    By JRGlynn in forum Plumbing Forum Discussion & Blog
    Last Post: 05-16-2011, 09:22 AM
  2. Back to back bathrooms without a double fixture?
    By junger in forum Plumbing Forum Discussion & Blog
    Last Post: 05-21-2010, 06:44 PM
  3. Adding bathroom back to back with existing - share 3 inch branch?
    By mturse in forum Plumbing Forum Discussion & Blog
    Last Post: 10-04-2008, 07:25 AM
  4. Back to Back 45 Degree Offset in Drain Line
    By louk in forum Plumbing Forum Discussion & Blog
    Last Post: 07-19-2008, 09:54 AM
  5. Back to back commode flushing problem
    By cvonkantor in forum Plumbing Forum Discussion & Blog
    Last Post: 03-12-2007, 08:13 AM
