Results 1 to 7 of 7
Thread: screw hole in copper pipe
    DIY Junior Member Jackie123's Avatar
    Jul 2010
    Hamiton, ontario
    Default screw hole in copper pipe
    Hi,
    I was putting a plywood sub floor down today in my entrance way on top of plank flooring and screwing the plywood down. When I was finish I proudly looked at my work. Thinking I was getting closer to laying down my tiles. Then I looked at my raditors and was hoping I was not all that dumb, unforunatly I was, removed the questionable screw was greeted by a shower.
    I have now drained the heating system(thank goodness it is summer) and have removed the new plywood and have a small hole in the inch coffer pipe. Is their some sort of patch I can put over the hole or would I have to have the pipe cut out and new piece put in its place. If I have to remove the pipe I will have to pull up some of the plank subfloor.
    Jackie
    In the Trades Wally Hays's Avatar
    Nov 2009
    A copper slip coupling will fix it right up. they come in many sizes.Name:  slp coup.jpg
    Perception is 3/4 of reality
    Slip coupling is the answer. There is no satisfactory patch which can be applied to the outside, notwithstanding the claims of Billy Mays.
    A slip coupling is the best, but I have brazed the hole closed when cutting it was not an option.
    Nov 2009
    I'll deny it in a court of law but I have "soldered" up a hole or two in my time. all in heat pipes, not water
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    An optional "Quick Fix without fully cutting the pipe"
    is to cut a slip fitting in half and create a saddle, clean and debur the saddle , solder the saddle over the small screw hole with the proper flux and solder.
    They also make a "Powerseal Repair Clamp" type product for ths but may not fit under the plywood properly.
    Kevin
    To do that properly, cut it OFF CENTER, so you create a piece with a slight "C" appearance. That will "snap" onto the pipe and create the pressure necessary to make the tight fit a proper solder joint requires.
  1. Screw through ABS pipe :-(
    By stern_howie in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2009, 02:47 PM
  2. Screw in Waste Pipe
    By Billy Beru in forum Plumbing Forum Discussion & Blog
    Last Post: 09-29-2008, 07:37 AM
  3. Repairing Screw Hole in ABS
    By nsblue in forum Plumbing Forum Discussion & Blog
    Last Post: 01-23-2008, 06:31 AM
  4. Hole in Copper Pipe
    By wackysue in forum Plumbing Forum Discussion & Blog
    Last Post: 08-25-2007, 07:39 PM
  5. screw hole in pvc vent pipe
    By permapak in forum Plumbing Forum Discussion & Blog
    Last Post: 06-09-2007, 05:54 PM
