Results 1 to 8 of 8
Thread: Caulk between pedistal sink and wall?
    DIY Senior Member CarlH's Avatar
    Feb 2007
    Northern VA
    Default Caulk between pedistal sink and wall?
    I will be removing a pedestal sink as a part of a bathroom remodel. Currently it is caulked at the rear where it meets the wall. When I reinstall the sink I am considering not caulking the rear edge since I don't like the way it looks and because it tends to collect dirt like hinge dust from the medicine cabinet. I looked up the instructions for at least two pedestal sinks and they did not mention caulk at the rear, while I have seen it mentioned on at least on DIY web site.
    What is the norm for a pedestal sink install? Caulk or no caulk where the sink meets the wall?
    Don't cauilk it at your own risk.
    There isn't a whole lot holding a pedestal sink to a wall. Plumbers like to "stick" them to the wall.
    Inspectors like to see the caulk too.
    I find that clear looks better then white.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    To plumbers and some inspectors it a health safety issue,
    because by not caulking you are leaving a place for water and bacteria to hide and cause mold, mildew, and lots of nasty
    germs to grow,
    while some people think of the caulking to sick it to the wall like terry say's it much more of health issue
    also like terry say's i use the clear now days, it goes on white but when it cures it is clear !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Feb 2007
    Northern VA
    Caulk it is, and I hadn't thought of using clear caulk. That might be a better option. Of course the current problem might be the width of the caulk and the type used. Some tend to be softer or more pliable and hold more dirt than others.
    Feb 2007
    Northern VA
    Looks like part of the problem is that lavatory is not level from front to back. It is 5/8" lower at the front which is causing the gap at the top rear to be wider than it should. I'll fix that when it goes back in. All this time and I did not realize that this sink was not installed properly.
    You may want to pick up some toggle bolts and fender washers to suck that basin to the wall before you caulk.
    The parts that come with pedestal lavs are nearly impossible to use. For us, it's a trip to the hardware store for the toggle bolts and fender washers, and some 1/4" 20 nuts, which if needed can be taken from a closet bolt set.
    There, I've done given away a nother top trade secret.
    Feb 2007
    Northern VA
    I found what looks like me sink on the Crane web site.
    http://www.craneplumbing.com/productDetail.aspx?id=2941
    It looks as though there is supposed to be a hanger bracket. Mine was not hung with the bracket. It is held in with screws into the studs. See picture below. I like the fancy hand crafted copper washers that were provided by the original installer. What do think about this mount? Should I try to locate the hanger? As long as lav is set level and in contact with the pedestal, I think those screws should be enough to keep the lav flush to the wall.
    And that's why I pick up fender washers at the hardware store.
    They look a lot better then that.
  1. Pedistal Sump Pump constantly runs
    By loughrins in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-09-2010, 03:47 PM
  2. Silicone caulk vs. latex caulk
    By midge in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2008, 06:28 PM
  3. Pedistal sink
    By sweetprudy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2008, 09:08 AM
  4. Mysterious black hose connected from wall under my bathroom sink to the sink drainpip
    By joe pipe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2006, 08:20 PM
  5. Caulk or Plumbers Putty for Sink Basket
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2006, 09:56 AM
