Results 1 to 9 of 9
Thread: shower stall faucet and door requirements
    DIY Junior Member n2learning's Avatar
    Mar 2009
    Missouri
    Default shower stall faucet and door requirements
    Building a basement bathroom that will include a 36" x 36" stand up shower.
    Can the shower faucet face the door of the shower entry?
    I read somewhere that this is NOT allowed. I wanted to get confirmation before I proceed with my design options.
    The door entry will probably just be a simple curtain rod, not a glass door.
    DK
    There are requirements on total size, and minimum door width, but I don't think there are restrictions on where the showerhead or valve are. There are convenience issues, but I don't think there are code ones.
    Jan 2006
    Rosedale, Md
    You can have the valve anywhere you want, but the shower head can not face out the entrance way.
    Plumber jimbo's Avatar
    I do not find anything in the plumbing code, maybe it is there. It might be a building code; mainly it is just not a great idea because the shower doors are typically not designed to handle continuos direct water flow.
    Having the shower head face the opening is the worst idea I've seen in practice.
    1) Water will be all over the floor
    2) When ever you turn the shower on, you won't be able to duck the cold water that comes out first.
    3) When you get tired of the above two items, you will find out that they don't really make fittings to move the shower head, though you could use a hand shower and hose.
    I've only seen it done a few times, and that's normally when called out to change it.
    A curtain rod with curtain isn't going to help much.
    Mar 2009
    Missouri
    Thanks for the replies, especially Terry's point 1 and 2.
    As to point #2, in a 36" shower you won't be able to avoid the cold water unless you turn the faucet on before you enter it, and THAT is when you will discover that the shower head spraying against the shower curtain, or even a swinging door, was a TERRIBLE idea.
    DIY Junior Member Denzel Parker's Avatar
    Jul 2010
    San diego
    Use Shower Systems Kohler as its complete digital showering system with this audio accessory kit.
    Quote Originally Posted by n2learning View Post
    Thank you - was about to ask the same question.
  1. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
    By Saitek in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2010, 02:09 PM
  2. requirements for walk in shower
    By dlang in forum Shower & bathtub Forum & Blog
    Last Post: 03-03-2008, 09:01 AM
  3. Manhattan shower stall door
    By gfrangos in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2007, 10:18 AM
  4. Shower stall
    By vinci in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2006, 04:54 PM
  5. Turning walkin shower stall into bathtub/shower combo
    By Brian_Houston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2005, 05:13 PM
