mikewi
Hi all,
Thanks in advance for your time and help. I'm in the middle of a tiling project in my upstairs bathroom, and my downstairs toilet started leaking. Arg, is it jealous? I want to finish my upstairs bathroom, and not loose too much timing fixing this toilet in my basement.
I removed the toilet which was installed on a concrete slab, and discovered that there was no flange? It looks like it may have broken off or crumbled off in the past. A previous home owner must have attempted to solve this with a thick wax gasket applied directly to the floor. Here's a picture:
Since I'm in the middle of another project and this toilet is in a partially finished area of my basement, I'm hoping that there is a quick but sound solution I can use to install a flange. If the best solution is to bust up the floor and install a new drain, I'd rather do it at the same time I finish the basement, which would include putting in a shower drain.
The cast iron looks corroded and rough, but do you think I can get away with cleaning up the inside of the cast iron pipe and using a compression flange like one of these?
J-Tec/Bruco 4" Cast Iron Closet Flange Replacement - Compression ABS
Oatey Cast Iron Twist-N-Set Flange
Thanks much,
Mike
Lynnwood, WA
BTW: The good folks at the johnbridge.com DIY tile forums recommended terrylove.com.
Thanks much,
Mike
Lynnwood, WA
